It still tell me that the dehumidifier is full even if i emptying.
That's generally what happens when the bucket is reinstalled and it doesn't trigger the bucket removal safety switch. Remove the bucket and look up inside the cavity for a protruding plastic trigger type switch. The bucket must make proper contact with it, so the the unit will run. Before removing the bucket, make sure the unit is turned ON. That way, when you reinstall it and trigger the switch correctly, the unit will start automatically When you reinstall it, be sure that the top and bottom of the bucket fit squarely into the cavity holder. Also, check the float level in the tank, to see if it is locked in the UP position. If it is, giggle it just a bit, to make it return to the DOWN position.
If that fails to solve the problem. Turn the Master ON/OFF Switch to OFF and unplug the unit for 10 minutes. After the elapsed time, plug the unit back in and turn the Master ON/Off Switch to ON. Hopefully during that 10 minute timeout, the unit's electronics have reset themselves and the your will have reverted back to the original factory settings. You can then rest them the way you want to.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
