Question about Kenmore HE2 Plus Front Load Washer
Black marks on white clothes - Kenmore HE2 Plus Front Load Washer
  • 57 Answers
If it looks like straight pencil lines possible cause is the tumbler in dryer is rubbing metal against metal on the bulkheads usually followed by loud noises check your tumbler and bulkheads
Posted on Jun 27, 2009
Its giving my clothes black marks
It is to hot. read the labels in your clothing, what temp you are allowed to use and dial that in on the iron. Still burn marks, bring it back, because then the thermostat s not good.
Feb 05, 2015 | Tefal Irons
My washer leaves black marks on my clothes. I do not use fabric softners
Do you mean Black, really black marks? Perhaps dark brown.
Some marks comes from moldy seals, other marks comes from leaking gears from the machine. Examine the marks, check if those marks are oily or not.
Nov 27, 2009 | Fisher Paykel EcoSmart GWL15
Help! black marks on white clothes w/maytag dryer
usually when this happens it's from the felt seals that are on the drum,the clothes are passing through the seal and hitting the rollers,as for other problems if the timer is bad the seals and you have a noise problem,you might just want to get a new dryer,nobody can help you without the model number and if you're gonna try to fix this you'll have to send alot more info than what you sent
Jan 02, 2018 | Maytag Dryers
Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
Front loader leaving black marks
had the same problem. Tried changing the washing powder to no effect.
Jul 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Black marks on clothes after washing
Try running a few caps of CLR in the washer (without clothes, of course!) Then run a few cycles with no additives. I've heard that powdered lemonade works also. Might be safer to try first. Good Luck!
May 23, 2009 | Washing Machines
I'm getting burn marks on clothes. Think it's the seal on the back of dryer? Must hang to dry all white clothes, so what's the point o fhaving a dryer?
The gasket between the drum and the back panel may be worn or missing.  I had a similar problem with a 34 year old dryer when the felt gasket wore out and allowed metal-to-metal contact between the drum and the back panel.  The clothes would get pinched between them and make a black "kiss" mark.
May 18, 2009 | Dryers
Black Marks on Cloths
either the roller are degrading or the belt the black is caused by the grinding of the dryer as it spins and has no cushion left replace the rollers
May 03, 2008 | Maytag MDG2706A Gas Dryer
Whirlpool calypso GVW9959Q - Black stains on whites
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer
Feb 14, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
132 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
