Question about Frost Free Sillcock, 12"
Sillcock leaks even when off. does anyone make a repair kit?
  • 3,600 Answers
Have you tightened the nut around the valve or have you backed off the nut then screw it in and then tighten nut? And yes you can get a kit at any hardeware store but you will have to take it apart to get the right seals.
Posted on Aug 06, 2009
How do i identify my outdoor faucet, cannot really read the numbers there is an arrowhead logo with a diagonal banner across it letters nw and asse Py9 maybe?
This is as you may have guessed, an Arrowhead sillcock.You should be able to replace the washer if you can find the bibb screw. Hold a bucket in front of asillcock and have someone turn the water on for 2 seconds. The bibb screw and what is left of the washer should shoot out. If you lose these parts, you can take the stem to the nearest plumbing supply, lowes, home depot or hardware store that carries Arrowhead sillcocks. They should be able to either give you a repair kit, or a whole new sillcock which you can take apart and just use the stem. It must be the same length to work properly. Before you install the new stem, make sure the bibb screw holding the washer in is tightened. Good luck!
Apr 15, 2017 | Banner Plumbing
DIY A/C Recharge Are they worth the money and effort?
The problem with these kits is they will usually get you some cool air. However, they can do more damage than harm, since it is not possible to determine how much, or how little refrigerant is in the system using these kits. There is a prescribed amount of refrigerant for each system to provide optimal cooling. Too little makes the system work too hard to cool the car down. Too much can overcharge the system and cause premature compressor failure. Besides, most often it is a leaking system that brings on the need for recharge. It is best to have it checked out, repaired, and charged to specifications. Sadly, this is not usually an inexpensive option.
Sep 12, 2014 | Vehicle Parts & Accessories
Hansgrohe axor repair
follow this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals.
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 26, 2013 | Home
Carburator on f100 truck leaking fuel, how to repair
Each carb kit comes with compete instructions on repair.
Jul 09, 2012 | Ford F-100 Cars & Trucks
I have an American Valve M72AS Frost Proof Sillcock that is leaking around the stem when turned on. I replaced the packing under the handle with no fix. Is there another packing/seal deeper inside? How...
AMERICAN VALVE 1/2-in Dual Pattern Brass Sillcock Valve M72AS...
Do NOT purchase this product... Mine lasted about four years for me before the internal stem/rod cracked. This caused a constant leak when it was turned on. Doing research for parts... I've noticed a lot of reviews on the internet about this same problem as to it leaking through the handle. I thought it was a gasket problem but after analyzing it, it turned out to be the "Integral Vacuum Breaker" system malfunctioning after a few years of use. The tip of the stem is a moveable item loaded on a spring and if it gets stuck closed, the water in the stem/rod does not drain out causing water to stay in the center stem/rod and of course freezing during the winter. When Spring comes and you turn on the system, that's when it leaks in and around the handle.
Another important note: I could NOT find replacement parts i.e. center stem/rod therefore causing me to buy another new Freeze-Proof Sillcock. It doesn't stop here yet....The newer ones are mostly made of aluminum and the center stem/rod is all aluminum...NOT copper!!! This part being all aluminum which I believe will be a major problem to come!!! As you know aluminum creates lots of oxidation with layers of white aluminum powder. This will now be going through your hoses that might feed your garden/food, your pets water bowls outside and your pools!! This is not good. They need to keep this stuff copper or CPVC but NOT ALUMINUM.Look up "Aluminum poisoning"
I have pictures of this (center stem/rod) and how I fixed the old copper center stem/rod for a back up when my aluminum one I just bought from Lowes fails in a few years. I tested it and it works (my old copper stem/rod)!!! I fixed mine by removing the spring in the tip and putting the tip back in the stem and filling the center of the stem/rod with Liquid Nails adhesive. If I was to do it again, I would use a Rubber Silicon via a tube gun.
My suggestion is to go to the old type of Frost-Free Sillcock "BRASS" NOT ALUMINIUM and doesn't have a hollow center stem/rod for water to freeze in and also doesn't have the anti-Siphon design. It might be a neat design but when the parts start to oxidize/rust etc. it then will stick and keep the water from being aloud to leave the stem/rod therefore causing a crack and WILL leak when opened during the Spring.
Jun 10, 2011 | Home
Muellet sillcock - two units-one no water flow at all; one unit very little flow-- less then one year old -- this seems to be a common problem
Either the rubber seal that shuts off the water is stuck or jammed sideways, or the sillcocks are corroded internally, which with everything being made in China is no surprise.
May 12, 2010 | Mueller Industries No.104-119 12" 3/4MIP...
When I turn the water on it comes out of the spout and out of the vent cover are there repair kits for these. I took the vent cover off and the water is coming through the bushing that is threaded down in...
I am guessing that the vent cover you are refering to is the vacuum breaker cap on the top of the faucet. The vacuum breaker is there to prevent water from being sucked back into the system. If that is what you are refering to then yes they do make parts for them, but you will need to know the manufacturers name and possibly the model, then start calling or surfing around. Hope this helps.
May 10, 2010 | Frost Free Sillcock, 12"
When I turn the water on it comes out of the spout and out of the vent cover, are there repair kits for these. I took the vent cover off and the water is coming through the bushing that is threaded down in...
There are repair kits for frost free silcocks, if you can find one that fits yours. Sometimes it is more difficult to find a repair kit than to replace the whole thing.
Mar 16, 2010 | Frost Free Sillcock, 12"
Frost Free Sillcock, 12" Logo
1,375 people viewed this question
Top Frost Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Frost Plumbing Expert? Answer questions, earn points and help others
