Question about Magic Chef CTB1922 Top Freezer Refrigerator
Refrig compressor only click but does not engage
Refrig compressor only clicks but does not engage model # ctb1922grw
was running fine but it seems that the compressor is not coming on....
compressor was a little hot to the touch. could it be a relay..??
  • rmondell Jun 27, 2009
    i got a relay overload combination and installed it ...the unit ran for about 15 minutes and then stopped...only the interior light comes on now.
    how do i check it with an ohm meter?
  • 82 Answers
Probably the start relay or a bad overload (check overload continuity with a volt/ohm meter) Maybe a broken or burnt off wire inside the compressor terminal cover. Possible, but unlikely compressor locked up. Unplug it before getting into the terminal cover.
Posted on Jun 27, 2009
  • Ronald Long Jun 28, 2009
    Now it gets tough long distance. Did you install an exact replacement or a one size fits all? Sometimes the generic ones are not matched properly to the compressor application and burn open from excess load. Can you isolate the overload only and check for continuity on the 1x ohm scale. You may have an open compressor now but seems odd it would run a little bit then quit. I think you still have a control problem that we just have to isolate. Are you familiar with an ohm meter?
    Any luck? I had a late nite. Is ther a chance your fridg just went into defrost cycle after replacing your relay? Thats about the only thing that kills the fans and compressor.
Have a kitchen aid side by side refrig that stopped working tonight. Model KSRB25FH with ice maker. Noticed ice was wet earlier today and tonight food has thawed in freezer section and refrig was not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Microwave Ovens
Is not making ice and is very warm from middle to top on both sides of my side by side kenmore 106.56932600
Greetings,
is there any ice frozen on back wall of freezer panel..if not, check to see if all the fans are operating..does the divider between the refrig and freezer doors seem real hot? if so, look for a stopped condenser fan motor....now, does the compressor run? sometimes you hear the condensor fan running and think the compressor is running...these things will click every fives minutes if not running..So, listen carefully, touch the compressor..is it hot? is it hot and clicking? if clicking, UNPLUG and remove the relay off compressor..shake it and if bad..it will rattle. Replace the relay if bad. The compressor could be bad and be clicking as well..anyway, let me know if it isn't it
Bruce Denton
Jan 24, 2011 | Refrigerators
Hello I have a GE lower freezer model # PDS22SBSARSS AND THE TEMP CONTROL is clicking and the digital readout is doing weird things by indicating wrong temperature and clicking, it stops after awhile...
Roll the refrig out and determine where the clicking noise is comming from. If it is form the small rectangular cover on back, replace the main board (WR55X10942) located under it. If the clicking is comming from the compressor area (at the very bottom, behind the cover which goes all the way across the bottom of the refrig) then replace the relay (WR07X10086) and overload (WR08X10061) located where the wires attach to the compressor, and for good measure, the capacitor (WR62X79 ). (located just to the left of the compressor)
Jan 12, 2011 | GE Profile PDS22MHR Bottom Freezer...
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Refrig is running, but freezer defrosted and food side seems to be getting warm. Always blew warm air from bottom front, now just cold air.
Sounds like the compressor is not running. Try unplugging for 15 min. to allow compressor to reset. If you hear a clicking noise you may have a bad main board.
Feb 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Moved refrig. and compressor will not kick in
The unit may have gone into the defrost cycle. The fans and compressor will be off during the defrost cycle. Has the unit been plugged in for more than 30 minutes since you noticed it stopped? If so, you will see a round plastic knob recessed about 8" back in the console on the fresh food ceiling. Rotate this knob clockwise with a flat blade screw driver until a distintive click, louder than the tiny clicks made while rotating the knob. If the fans and compressor come on, replace the timer (68233-3).
If the fans and compressor do not come on after rotating the timer, you may have a bad cold control of loose wire in one of the molex connectors from the move.
Apr 29, 2009 | Refrigerators
I have an Amana bottom freezer, model BX20S5E that is not cooling properly in either compartment. I have replaced both the defrost thermostat and defrost timer (new). Still no change... what I do notice is...
check door gaskets and see if problem is moisture,or air gate to fridge compartment not working properly.I would recomend verifying defrost cycle is working by turing defrost timer to defrost cycle,it will click when engaged when unit is frozen and heater should come on if all is well,if not heater is probably culpret if the rest is new.
Apr 09, 2009 | Amana ARB8057CSL Bottom Freezer...
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
REFRIG SEEMS TO TURN OFF AND ON , MAKING A CLICKING NOISE
You unit has a ptc relay on the compressor. It needs to be replaced. If you need tech. advice get back with me but it's pretty straight forward. Unplug frig and take the black cover off compressor. There will be the relay. When you go into the parts house ask for a 3 in 1 they are a lot cheapier. let me know how it goes ken
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Elite refrigerator stops cooling - Relay keeps cycling
the relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
Dec 17, 2007 | Refrigerators
Magic Chef CTB1922 Top Freezer Refrigerator Logo
361 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
