Question about Refrigerators
I have a whirlpool side by side model #GD5YHAXNL.
I have a whirlpool side by side model #GD5YHAXNL. The freezer is working well ( a little too well as everything is frosting over) bu the refrigerator isn't working at all. Please help.
    President:
  • 1,136 Answers
Hi, The frost you are seeing is because the self defrosting cycle is not working. Remove the rear inside freezer panel and test the defrost heater and bi-metal switch for continuity, Ifeother part does not have continuity, it will need replaced. The bi-metal switch is the most common problem and is located on the top of the evaporator coil.
If both of these parts prove ok, the defrost board will need replaced. The defrost board is located in the fresh food section in the control panel.
I hope this helps you. Please let me know if I can assist you further with this issue.
Thanks
Vic
Posted on Jun 27, 2009
Our Whirlpool Gold Refeigerator Model GD5YHAXNL 03 has stopped making ice at the normal rate. It only drops about a dozen cubes in a 12 hour period (versus a complete fill normally). I noticed the infrared...
This is a WAG, but I would suggest you try to align the two sensors until there are green lights on both sides. According to the instructions, it is to operate like the garage door sensors. When the sending unit beam hits the receiver unit, you should get green lights on both sides.
Someone might have jarred one or the other unit out of alignment, and you might not need any parts to fix it.
Jun 10, 2011 | Whirlpool Refrigerators
WHIRLPOOL GD5YHAXNL 03 Problem: In door ice
You new to replace the augor motor.
It is normally under the dispenser on the INSIDE of the freezer door.
Two 1/4" screws hold a little panel on.
Sep 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator not cooling freezer seems to be working
my icemaker makes ice and water but the ice doesn't come out when pushing the button what is the problem?
Aug 30, 2009 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Side by side: freezer temperature fine, fridge too warm
sounds like your auto defrost isn't working. my maytag does same thing. the cooling core in the freezer is probably iced up. when it becomes solid ice no air(or very little) can pass by, leading to too little cold air reaching the fridge. you can try to cycle the temp levers(usually doesn't work) you can manually defrost the freezer. pull the cover off the back(inside freezer) and use a blow dryer. not sure how much parts are for whirlpool. hopefully this is just a one time thing. there are tests you can find to check some of the parts.like the heat element for the defroster, just search for the tests.
Jul 30, 2009 | Whirlpool Refrigerators
Ice maker works but will only give crushed ice on the cube settin
little arm on side of ice bucket controls that..check it and the solenoid at back for freezer that trips it.
Jun 08, 2009 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED5PHAXSB side by side refrigerator not cooling...
There are a lot of possibilitys. You'll have to use the process of elimination.
But it could be the thermostat (make sure your setting is midway) The milk spoiling indicates it is too warm so bacteria is breeding
Get a refrigerator / freezer stand alone thermostat (about $5) That will give you accurate readings. The fridge shoud be between 35 and 40 F and the freezer 0 plus or minus 3 when set correctly
It could be your condensor fan is clogged or just that your coils need cleaning (underneath or behind) Use a vacuum with the brush end or chisel point. Dust can cut you efficiency by 20 or 30% by itself.
Assuming this is frost free model the defrost timer may be acting up in the freezer.
Forgive me for not knowing where the coils are and if it is frost free but I can't find a manual for this particular model. However the principles apply in any case.
May 09, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool Refrigerator Freezer Fan
yes you can unplug refrigerator remove carry it to appliance store or model #
Apr 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Model ED5FTGX side by side won't get cold
check to see if c ompressor is running if not it might just be realy thats the little box mounted on the left side
Jan 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
188 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
