Question about Campbell Hausfeld PW1750 Electric Pressure Washer
Need to know how to wire the on off switch on a 1750 psi pressure washer. it is a 4 pole switch
2 Suggested Answers
  • 420 Answers
SOURCE: Gun
Replace the wand (Gun) The valve is not repairable.
Posted on Jun 16, 2010
Karcher k3.86 on/off switch does not work
If you are certain it is the switch, try looking on Ebay for a replacement switch.
Apr 16, 2014 | Karcher 1750 Psi Elec Pressure Washer
Anybody know how to remove the wheels on a Husky 1750 power washer?
where does the link-mechanical gov. rod connect to the carburetor on the craftsman pressure washer number 919.762350.
Sep 28, 2013 | Dayton Wire Wheels Dayton Twin-Piston...
I need a manual for a shop force 2000 psi pressure washer. It is 1750 working pressure. It has 2.4 hp ohv engine. 1.6 gpm
I have a question because I am using a gas pressure washer more long time but I want to use electric pressure washer so please tell me something about the best electric pressure washer. http://car-gears.com/
Jul 28, 2011 | NIB Shop Force Universal Pressure Washer...
Low pressure on the pressure washer
Most likely your "O" rings or seals have gotten hard and are leaking. Sorry I don't know your equipment well enough to tell you how to change them but you can most likely find the info at your manufactures web site.
May 26, 2010 | Karcher 1750 psi Electric Pressure Washer
1750 psi Electric Pressure Washer: My pressure washer is losing pressure and is pulsa...
I have d'same problem before. replace the head component with the 3 little cylinders,springs etc.. its a 1 piece part.
May 06, 2010 | Karcher 1750 psi Electric Pressure Washer
Pressuer washer not turning on
Inside machine are safety switches, you probably have a stuck on. Take apart, plug in and test with a tester to see where power is not getting to. I am guessing a safety switch is stuck.
May 02, 2010 | Karcher 1750 psi Electric Pressure Washer
My Karcher 1750 psi electric pressure washer is making in/out loud noise when switch to On and idling not pressing washer trigger.
thats normal, it is reducing the built up pressure that is not needed until the trigger is pulled.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 01, 2010 | Karcher 1750 psi Electric Pressure Washer
How to connect the cold water supply to K 3.65 Jubilee? In the instruction leaflet, figure J, number 1, 2, and 3 I seem unable to connect it. The above is a pressure washer.
Hi all you need is a 3/4 tap fitting from a diy store.
Maybe a hoselock 3/4 male and female fitting that will fit a standard 1/2" hosepipe. If struggling I can send you a link to the fitting on ebay but if you type in karcher tap connector you will see it by the seller vavcandwash.
Feb 14, 2010 | Karcher 1750 psi Electric Pressure Washer
Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Apr 24, 2009 | Garden
Karcher K3.92 M 1750 PSI poweer Washer motor won't start. Followed Reset/Test/Reset sequence with cord plugged directly into outlet. Light on cord near Reset comes on when Reset pressed down but goes off...
They are sensitive to large extention cords. My father in laws pops reset when a small cord is used. If internally shorted- motor will continually pop the reset even plugged direct to outlet. Check voltage at outlet.
Jun 19, 2008 | Karcher 2500 PSI Pressure Washer
Campbell Hausfeld PW1750 Electric Pressure Washer Logo
171 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
