Question about HP Photosmart C6180 All-In-One InkJet Printer
HP C6150 Printer that turns off then back on repeatedly
I have HP Photosmart C6150 All-in-One Printer that turns off then back on repeatedly. It will go off the tries to restart for about 10 sec. and the shuts off again over and over. It will not stop this cycle until it is unpluged. HP Photosmart C6150 All-in-One Printer Turns Off Repeatedly. It will go off the tries to restart for about 10 sec. and the shuts off again over and over. It will not stop this cycle until it is unplugged. I already checked all your suggestions on the HP help page titled "The HP Product Turns off Repeatedly" The printer is connected wireless, and has no USB connections. I tried it in another room with no change.
  • 3 Answers
Thanks to Anuj Bhatt who previously posted:
Reset the printer by following steps
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Apr 06, 2012
  • win_vu
    win_vu Sep 18, 2012
    This method worked for me, and WITHOUT the replacement of capacitors. Try this first before performing invasive methods and save yourself time and money.
  • 14 Answers
Please DON'T keep posting messages that say "I had the same problem..." Those are useless!
If the software resets don't work, it's possible it's an electronics problem. Here is a repair note that worked for me:
http://www.fixya.com/support/t5821942-hp_photosmart_c6180_continually_powers
Posted on Sep 24, 2010
Mine's doing this too, did you figure out what caused it? it keeps looping to a Printer was shut down improperly, then it tries to restart...
Posted on Jun 07, 2010
  • greg_f537 Sep 01, 2010
    Mine is doing the same thing , has anyone found out what causes it and how to fix it ?
  • jpetro1 Sep 15, 2010
    Mine is doing this exact same thing. I tried the # and 3 reset and that seemed to work temporarily but it didn't last long before it started again.
Why does my HP Photosmart C6150 All-in-One only prints/scans full black page
Open the scanner cover and check on you to copy double-check scanner moves when the light comes from the scanner and see if it sees the glass as if it would be messy to be opened and cleaned
Jul 22, 2014 | HP Photosmart C6150 Wireless All-in-one...
Clearing a Print System Failure on the HP Photosmart C6150 All in One Printer
Try the below steps to bypass the error.
1) Press * and # at the same time
2) Press 1, 2, 3 and "support R0632M" should display
3) Press > and "information menu" should display
4) Press > and "configuration menu" should display
5) Press OK and "hardware failure status" should display
6) Press OK "failure status: clear". Press OK to clear
7) Press CANCEL
8) Press CANCEL
9) Press CANCEL
10) Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
You may need to repeat the above a few times as the error can change.
Aug 04, 2013 | HP PhotoSmart Office Equipment & Supplies
Print head diagram
While the printer is still on, remove all the 02 cartridges, be careful not to get ink on places where you set them down at. Close the cover, remove the power cord from the printer without turning the unit off. Clean the surface carefully with a soft and clean napkin, Wait for 20 sec, Put the printer back "ON" . Install one cartridge, close the cover wait for a message, then repeat with each of the cartridges. See if that will work. You can mail me for further explanation... Obehiadoghe@yahoo.com I hope to hear from you soon.
May 12, 2013 | HP Photosmart C6150 Wireless All-in-one...
Hello. i have the hp Photosmart C6150 printer. for
Press the button on the printer, to turn the printer off.
Then, press the switch on the power-bar, to completely cut the power to the printer.
Turn the power-bar on.
Turn the printer on.
Jul 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP PHotosmart c6150 keeps shutting on and off repeating the same meassage improper shutdown.
You need to reset the printer. I had the same exact problem with a C6150. Unplug the power cord from back "while printer power is on" (doesn't have to be fully booted just turning on). Wait 20 seconds, hold # and 6 keys together and plug power back in. Continue to hold until power goes off or semi-reset message comes up. Power up (if off) press OK for any error messages and let the printer cycle. Should be good to go. Mine sounded very noisy while it was trying to allign internally. I can only suspect that was the initial problem but this process fixed mine and it runs great now. Hope this helps.
Jan 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
Black ink will not print on Photosmart C6150; Ink
I'd do the reboot of the printer.Turn it off,unplug for 60 seconds,plug it back in,turn it back on and see if the black will work.After plugging back in it should clean the print head and then you can do a test page to make sure.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00728224&cc=th&lc=en&dlc=en&product=1153494
This site will show you how to print a test page.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
My HP Photosmart C6150 shows an "Out of Paper" message. I have repeatedly removed paper and added it back, message still shows & it won't print
Dear sir your printer problem is paper sensor when you stay paper then paper switch is open but this printer paper switch lever is broken or displace please chack it then solve your problem
Jul 20, 2009 | HP Photosmart C6180 All-In-One InkJet...
Same problem, hp c6150 turns on and shuts down in infinite loop.
In visiting with HP Support Personnel, this issue is most likely caused by a faulty power source. I have the same issue with our C6150 and they recommended that I look at replacing power cable. I am currently trying to find a new power cable.
Jun 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6150. Rollers do not pick up paper
Remove the rear cover a reallly scrub the black rollers with isopropyl alcohol. Scrub HARD
Jun 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
3,274 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
