Question about Maytag MZD2766GES Side by Side Refrigerator
I have a frige that won't freeze. fridge side won't get cold
I have a frige that won't freeze on freezer side keeps running. A tech said it could be the drier. Any suggestion if could be? I a maytag side by side mzd2766GES
  • 4 Answers
This seems to be a common problem with these refrigerators. I had the same problem a while back. Sounds like your defrost board is dead. part number is 12002104. You can find it at searspartsdirect.com
Posted on Jun 28, 2009
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
installed.
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My fridgedaire side by side freezer's condensor is freezing over and warming the fridge side, I defrosted it the fridge side is keep cool enough to keep food but the freezer side will not get cold to...
Hello, This is a type of faulty you can handle yourself, most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
I hope this will help in solving the fault.....
May 12, 2011 | Refrigerators
The freezer is COLD..freezes solid. Setting at low. The frige part is not cold and is set at high. Seems everything is going up to the freezer. Unit is just over 1 year old. Drinks are cool but not...
where is the freezer on top,side by side or the bottom.all a fridge does is blow cold air from the freezer to the fridge side that's it,if the fridge is warm there's a problem most likely in the freezer,a plugged drain or when you open the freezer door do you hear the fan blowing,if not you have a bad evap fan motor,also check your warranty it still might be covered.send the model number and i can help you,if you see water under the bottom draws or in the fridge section if the freezer is on top you have a blocked drain in the freezer.let me know what you find and i can help you
Feb 20, 2011 | Magic Chef Refrigerators
We have a Kenmore Fridge. The freezer will not freeze anymore but the fridge works fine. We did unplug the fridge and let it sit for 24 hours to see if that would help the freezer to work again. it...
IT'S FUNNY THAT THE FRIDGE SIDE IS WORKING AND THE FREEZER ISN'T,ALL THE MACHINE DOES IS GET COLD IN THE FREEZER AND THE EVAP FAN BLOWS COLD AIR FROM THE FREEZER TO THE FRIGE SECTION.IF THE FRIDGE IS COLD AND THE FREEZER IS RUNNING WARMER THAN IT SHOULD YOU COULD HAVE A SEALED SYSTEM PROBLEM,SOMETHING WGONG WITH THE COMPRESSOR OR A LEAK IN THE SYSTEM.THE GAS WILL CONTINUE TO LEAK AND THEN BOTH SIDES WILL GET WARMER AND WARMER.YOU CAN REMOVE THE INSIDE FREEZER WALL,LOOK AT THE EVAP COIL AND CHECK THE FROST PATTERN ON IT,WHEN IT'S RUNNING CORRECTLY THE WHOLE COIL WILL FROST UP BUT IN YOUR CASE YOU'LL MOST LIKELY FIND THE COIL PARSIALLY FROSTED OR JUST THE TOP OF THE COIL WILL HAVE ICE ON IT,THAT MEANS NEW FRIDGE TIME,IT WOULD BE TO MUCH MONEY TO REPAIR IT.LET ME KNOW WHAT YOU FIND WHEN YOU LOOK AT THE COIL AND WE CAN GO FROM THERE
Nov 23, 2010 | Kenmore 14.8 cu. ft. Top Freezer...
Water filter inside fresh food compartment keeps freezing up? Frigidaire brand 3-4 years old. Thanks, Steve.
hello,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze
Check the cold control, and also the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout....
Aug 08, 2010 | Frigidaire FRS6R5EMB Side by Side...
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator interior heating upwards of 90 degrees/freezer seems fine
is you freezer freezing if yes is your evaporator motor in the frezeer running.
if yes then it might be you damper assy that is not opening but on GE'S most of the times that run call with that problem the evap motor is not running does your frige have a computer at the back if you do then you have to trouble soot that computer or call a tech or just repl that board and if it doesn't work just return it
Oct 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
368 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
