Question about Magic Chef CTB1922 Top Freezer Refrigerator
My 11 year old fridge has a slight leaking problem. on occasion i will find a small puddle in front of the fridge and sometimes a little bit of water under the right side crisper but i can't seem to find to actual source of the water leak - any suggestions?
  • t42or1 Jun 27, 2009
    thanks for your help - i will try that out.
    President:
  • 1,136 Answers
Hi, The drain hole for this model is located in the control panel. There should be 2 - 4 screws that hold the panel up. remove those screws and the control panel should drop down. Flush the drain hole out and check up inside the hole leading to the freezer drain and see if there is ice inside the drain hole.
Most of the time, the drain inside the control panel is the problem.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 27, 2009
  • Victor
    Victor Jun 27, 2009
    You are welcome. please let me know if you are able to get it.
    Vic
I have a 10 year old GE Monogram refrig. We noticed a small puddle of oily liquid on floor beneath freezer door. It is accumulating about 1 tsp/day.
certain amount of oil is in the compressor motor casing to stop it burning out
it is under the same pressure as the refrigerant
I would say the oil comes from that casing
you could turn the fridge off at the wall
bring the fridge out to get behind it
and degrease the area to see if the leak is severe
if it is..... needs a fridge technician
not sure
check if cost of replacing the motor compressor unit
on a ten year old ge
might be more that fridge is worth
Nov 10, 2016 | GE Refrigerators
My 20 cubic foot fridge dairy upright freezer has started leaking small puddles of water underneath it is only 3 months old
Contact shop, less than a year old they are responsible for repairs / replacement. Have you read instructions to make sure that you have done all that you should regarding any draining of system thet is required.
Feb 22, 2016 | Freezers
20 year old Maytag jetclean model WU482 small hole in front bottom of tub leaks water
At 20 appliance years of age, your Maytag may start leaking like a sieve but you can try patching the hole you see and hoping for another 20 years.
Jun 19, 2017 | Dishwashers
Occasional small puddle of water on floor in front of unit on door handle side. it is a 25 yr. old Amana no ice maker or water dispenser in door
there is a drain pan for condensation under the fridge. over this many years the is dust and lint that will fill the pan and displace the water on your floor. while your under there clean the coils. this will help get every year possible from your fridge
Jul 27, 2009 | Refrigerators
Small puddle of water on floor in front of fridge
there is a drain pan under the fridge where water is collected then evaporized from the heat of the compressor thet sometimes the pan cracks or the pan is unleveled .check pan
May 23, 2009 | Bosch Logixx KDR40423 Refrigerator
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Mar 28, 2009 | Frigidaire FRS26R4A Side by Side...
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Magic Chef CTB1922 Top Freezer Refrigerator Logo
220 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
