Question about Craftsman Garden
My lawnmower will crank but when I put release the
My lawnmower will crank but when I release the clutch or put the blade in gear it shuts off.What is the problem. It is a dty 4000, 18 horsepower. It's approximately 6 years old.
  • nmtaylor Jun 27, 2009
    Thank you for your response to my problem with the lawnmower. I unpluged the safety switch under the seat and plugged it back in and it is working fine now. Again thank you for your help. Nancy
  • 49 Answers
SOURCE: craftsman snow blade install instructions
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of the blade and you will see a parts diagram of blade. Hope this helps.
Posted on Feb 06, 2009
  • 109 Answers
SOURCE: engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Posted on Apr 23, 2009
rwvanlue
  • 486 Answers
SOURCE: 14sb engine running when blade clutch is engaged
Normally I believe this mower to have a Kawasaki engine, and the main jet and 'pilot air hole' need to be cleaned. You are running a lean condition, and when the blade is engaged, the engine does not have enough fuel to continue the extra load. A small test for this is to engage the blade and the choke at the same time. If the engine has enough fuel to continue running and engage the blade, this confirms the lean fuel condition. Cleaning those jets will solve the issue.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
  • 394 Answers
SOURCE: DTY 4000 tractor dies when engaging pto, new
This is just a suggestion. Try pulling the choke out about one third to one half and then engage the PTO. Sometimes the air idle adjust screw port gets a tiny speck of debris in it. If with the choke partially out and the PTO engages the just grab a screwdriver and turn the air idle mixture screw counter clockwise a hair.
Posted on Apr 30, 2010
Testimonial: "Hit on the head with such a simple solution"
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
Lawnmower dies when I put it in gear, why
Sounds like a safety switch somewhere.. Check the seat switch first, that is what happened to mine. Does it smoke the belt and stop? or just cuts off when you release the brake? If when letting out on brake, pretty sure it is the seat safety.
Oct 07, 2014 | Garden
Starter gear strips after a couple times of starting on a 20hp briggs&stratton engine on a Murray lawnmower
bad compression release valve do a valve job and put in new valves or crank bearings bad do short block better just by new engine save the head ach with the motor valve job 100.00 per cylinder short block 300.00 or 400.00 plus 150.00 to put to gether best buy new tractor
Sep 11, 2014 | Murray Garden
Why does engine stop when clutch released or blades engaged?
Make sure have a good battery when you start the blades on any lawnmower it need lots of power to get it going
Jul 17, 2014 | Murray Garden
High speed on lawnmower
High speed is good..BUT you can drive it more slowly by loosening pressure on the clutch handle. Pull it very gently, and drive more slowly. The belt that is around the blade shaft runs the wheels
Pulling the clutch moves a gear in a rudimentary
gear box. Easy does it!
Jan 21, 2014 | Craftsman Garden
My sears craftsman riding mower will crank just fine, but as soon as I try to either put it in gear and release the clutch to go forward or backward, it shuts off. It also shuts off when I attempt to...
Many folks have found that a defective relay in this mower to be the cause of the "stall when i take my foot off the clutch" issue. The relay is connected to the safety switches which turn the mower off when no one is in the seat, etc.
Aug 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden tractor engine shuts off
Sounds like the operator present seat switch is not working. You can run the motor out of the seat, but not with the blades engaged. You didn't list what model, but usually hte seat switch is connected to the negative side of the battery, and grounds out the magneto, so you can't test it to ground. Put your tester on 12+ battery, and then to both sides of the seat switch. There is usually 4 terminals on seat switch. Some moodels have grey wires for the mageneto circuit, you can tell by whatever color also goes to the clutch switch too.
Aug 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
I have a Troy Bilt riding lawnmower(Big Red Horse) 23hp, when I engage the blades it draws the amps down below 12, and continually draws it down until the blades shut down. I have replaced the battery. It...
I'm guessing the blades operate from an electric clutch and you have a short related to the clutch. Check your switch, wiring and clutch for bare wires shorting to ground.
Jan 07, 2018 | Garden
I have rjdeing lawnmower with a BRIGGS&STRATTON 13.5 OHL WHEN YOU PUT IT IN GEAR AND ENGAGE THE BLADE IT LOSES POWER WQNT RUN. FAMLEY 4BSXS.3442VM 275943
if you mean that when you let off the clutch pedal and/or engage the blades, the engine dies, lift the seat and make sure the connector is firmly plugged into the switch attached to the seat.
Sep 28, 2009 | Briggs & Stratton Garden
Engine stalls when clutch/brake pedal is released
Apr 21, 2009 | Garden
Garden Logo
131 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
