Question about Toshiba SD-V296 DVD Player/VCR
The DVD tray will not open. Was working just fine. There is no DVD stuck inside Thank you
  • gshaubrich Jun 27, 2009
    Unplugging worked like a charm. Thank You for the tip
    Problem Solver:
  • 5 Answers
Unplug for 5 minutes, to reset computer, when repowered and turned on the eject dont work, the unit needs serviceing, if out of warrenty, get a new one.
Posted on Jun 27, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
Posted on May 13, 2009
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
I have dvd/combo Apex GT1417DV. The problem is there is a DVD stuck inside. The disc tray will open and close with no sign of the DVD inside! Any suggestions? (My kids have also loaded a 2nd DVD into he...
Hello
The first DVD you inserted may have slipped into the cabin of TV. It will be there inside, but to take it our you have to open your TV and take the loading mechanism out of it. It is a semi-skilled job, if you have confidence, you can do it yourself. When taking out the mechanism, make sure not
to damage any connection wires from DVD player to main board of the TV. OK.
Jun 03, 2011 | Apex Digital GT1417DV 14 in. TV/DVD Combo
Tray is jammed. stuck part way open and won't seem
same problem with me... did u managed to resolve??
Sep 03, 2009 | Eclipse (AVN7000) Car DVD Player
May 13, 2009 | Panasonic DVDS97S DVD Player
The DVD draw cover is stuck opened and the Standby light flashes but the tray remains inside. I am unable to close the cover or to have the draw open. It's just stuck in the up position. There is no DVD/CD...
You can do one thing in this conditions you can resolve your issue by changing the tray with motor lens set other than this you can't do anything because in this case max there will be a damage of lens, so kindly check with this to resolve your issue.
Apr 11, 2009 | Philips LX9000R System
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Oct 02, 2008 | Sanyo DVW-6100 DVD Player/VCR
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
I had the same problem. I opened up the unit and gently released the tray from inside. It has been working fine since - except for the problem I just posted i.e. the remote does not work.
Nov 17, 2007 | Memorex MVD2027 DVD Player
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
Toshiba SD-V296 DVD Player/VCR Logo
208 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
