Question about JVC Mobile Mini Note MP-XP7210 Notebook
Cannot Switch On!
When i press the Power button, nothing happened!
The screen is not on, the fan is not operating, no sound from harddisk...
    Guru:
  • 134 Answers
There are a couple of things that you can try. plug in AC adaptor, then press the Power button again, if it work, There might be a problem with the battery pack. Try using a replacement battery pack of the same type.
if it not work, motherboard problem, there is some fuse protection is burn. you may consoder sending it back for repair. hope this helps.
Posted on Nov 06, 2007
Pc doesn't start up
If nothing happens at all it sounds like a power problem, check the fuse in the mains plug, check for an on/off switch on the back of the computer, if neither of these are your problem then it may be a faulty power supply or simply a faulty switch on the front. Hope this helps.
Mar 03, 2013 | Computers & Internet
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
Hi, I have bought this dell vostro 1015 laptop one and half year ago. Day before yesterday my windows XP hanged and I was unable to shut down. So I pressed power on button for few seconds to switch off...
It sounds like your hard drive has gone bad. As this is a laptop you can try to reseat the hard drive, if that does not help then it might be a case of hard drive crash.
Oct 29, 2010 | Dell Vostro 1510 Laptop
Computer wont turn on
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattch both.
Make sure motherbord is not ground with cabinet.
When you power up the computer press F1 or F2 or "del" key then enter in bios .
Make sure in bios your harddisk is detected.
If not then change SATA or IDE cable of harddisk.
Then check .Go to boot menu nof bios then set first boot device as your harddisk.Then save settings and exit.
Let me know if you need further assistance.Thanks.
Nov 21, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Computer will not start up. A lound whine (fan?) is heard and nothing comes up on the screen.
Probably a bad harddisk, and no operating system will be loaded.
New hard disk and install a new operative
Linux is free and legal
Nov 10, 2009 | Dell Dimension C521 PC Desktop
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
Can see nothing on screen
press function and f5 at the same time
Mar 21, 2009 | Acer Aspire One Netbook 8.9" Notebook
ASUS Z91H PUSHED POWER BUTTON BUT WITHOUT DISPLAY
Try pressing the power button and press [del] button. See if it goes to the bios setup page. If it does, have your harddisk checked. It could be corrupt OS or problem with your harddisk.
Sep 12, 2008 | Computers & Internet
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Motherboard
If you use ATX power supply
Follow these steps
Switch on the power supply
Hold the power button approximately for 10 Secs , your system will be switched off. Now switch on the power supply and press the power button to return normal operation.
Some times pressing reset button also solves the problem
If above procedure fails , please check for any loose end connections inside the cabinet. memory slots, any pci slots also check the battery .
Hope this would help
Best of luck
Jan 29, 2008 | Computers & Internet
JVC Mobile Mini Note MP-XP7210 Notebook Logo
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tre Elkins
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
