Question about Craftsman 1 Hp, 4 Gal. Air Compressor
I have a craftsman 1hp 4 gal compresor. It's not building pressure and air is pumping out of the air filter not in???
    Champion:
  • 225 Answers
Sounds like reed valves are bad,sometimes you can take the reed valves and flip them over for short fix,best to put new one in unit.
Posted on Jun 27, 2009
Actually these reed valves a pretty tough. They don't flex but rather rise and fall in the reed cavities.
I had the same problem and found the head gasket blown. This gasket lies between the head and the upper reed plate and has only a 1/4 inch strip of material between the intake and output reed valve cavities. Periodic retorquing of the head may be advisable.
Posted on Sep 11, 2012
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
I have a 3 gallon 1HP Craftsman air compressor has worked fine for years but now it won't build air pressure over 20lbs. Any suggestions?
Make sure there are no air leaks first.
Your pressure valve may need resetting or replaced as it could not be working. Your compressor might be wore out.
Is there a gizmo that you can turn to set pressure. if so that might not be working if you have tried to set it.
Sep 09, 2014 | Craftsman 3 gal. Air Compressor, 1 hp,...
The compresor is not building up the pressure, it only reaches like 15 PSI .. and is not the drain valve
check the regulator valve. the black cap must be pulled out slightly to allow it to turn. adjust that while watching gauge for change. there is also another pressure release near the pump be sure it is seated fully.
Jan 16, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
1hp 4gal 2 tank Craftsman Air Compressor not Compressing
Try emptying the tanks completely. There should be a bleeder valve for each tank. Sometimes after sitting for a while with pressure, the compressor won't have enough power to start. If you get the same response with empty tanks, there is a problem with the pump pistons.
Dan
Jan 11, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is building up
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing.... also drain the tank
Dec 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
The air is coming out of the filter instead of intake . Craftsman Air Compressor 12-gal 1hp model 921.166400
if acualy exhaust / engine pressure is coming out of filter it likely to be a bad valve...does engine blow smaoke or oil? is there also pressure coming out of oil crankcase?....let me know , we'll diagnose it! good luck, marty
Jun 14, 2009 | Craftsman Air Tools & Compressors
Air pressure gauge does not move on Craftsman 1Hp, 12 Gal. Air Co
I would say that the gauge needs to be replaced. These are common items so go to any auto parts or craftsman hardware store and purchase a replacement.
be sure to use some joint compound or teflon tape on the threads so u dont have any leaks.
please rate my answer. thanks.
Feb 03, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Lack of pressure
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
Oct 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 1 Hp, 4 Gal. Air Compressor Logo
537 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
