Question about Teac AG-V8060 Receiver
I can not figure out to wire my aftermarket radio in my 96 chevy
I cant get my memory to work and when i wire up my aftermarket radio my interior light does not work... my car is a 1996 Chevrolet cavalier
  • whstark May 11, 2010
    This Post shows a Teac AG-V8060 Indoor reciever, so the question makes no sence.
  • Jacob Blackwood
    Jacob Blackwood May 11, 2010
    Did you buy a wiring harness that plugs into the factory harness or did you cut the wires? Does the radio your hooking up have a memory wire?
  • 1,056 Answers
I bet you the "battery" supply wire touched a ground somehow and blown a fuse. This wire is responsible for the memory, since it always have battery voltage in it. Unless of course you take out the battery connection. I would recomend looking for that blown fuse first. If the stereo was hooked up right you should not have memory problem anymore and the interior light working again. If you still have memory problem, you probably have the "battery" supply connected to the red accesory wire, or you have them both together. Having them both together is not a bad thing, only that it should be connected to the "battery" supply. You can turn on your radio with the ignition switch off. If you hook both on the "accesory wire" you would loose all your setting and memory on the radio each time you turn off the ignition switch. Remember not to touch the speaker wire to the ground, because the amplifier in the radio will be fried up in a fraction of a second. Some good radio has a protection circuit for that, but don't bet on it. I am confident this will help.
Posted on Jun 27, 2009
I have a short somewhere in my 2004 Pontiac sunfire radio wiring that I cant find.
you may have shorted out the radio itself ---if changed fuse test line from fuse to radio if power then radio most likely damaged
Jul 28, 2017 | Pontiac Cars & Trucks
Radio not powering up
Factory or aftermarket? Check fuses (should be 2 usually one marked radio and one marked either cigar lighter or interior lights. If aftermarket make sure you have 12v on the memory wire (usually yellow) and ignition switched wire (usually red) as well as good ground on the usually black wire. If so then disconnect for a few minutes to reset
Aug 29, 2016 | Car Audio & Video
I have 96 chevy monte carlo the speedometer wont work
The problem is the radio change wasn't done properly. The first indication of that was when you said
"they changed the factory radio it and when you turn off the radio the speedometer works"
Other factory things commonly run through the radio even though you may not expect they would. I don't know what your wiring is like now. Did they hack the factory plug off? If not, it should be relatively easy to put the wiring back like it was. You could then either get a factory radio for that car cheap. Salvage yard, maybe ebay, maybe a friend has one laying around etc. You could seek out a proper wiring harness made to put an aftermarket radio in. Crutchfield is a great place to search for special harnesses.
If the plug has been hacked off and you just have wires hanging, you'll need to figure out what is what. Again, if you go to a Salvage yard (junk yard) you might find a 96 Monte like yours with a factory plug you could hack off and re- wire to your car. I will include a diagram showing that the speed sensor input is part of the radio circuit as well as a link to Crutchfield. I'm trying to give you options so you can pick the one that works best for you.
Find what fits your car Crutchfield
Jan 30, 2018 | Chevrolet Monte Carlo Cars & Trucks
I just got a 96 dodge intrepid from my neighbor he never had a problem with it until i got ahold of it. Last night the brake light wouldnt shut off i fixed that with the switch on the brake. But now for...
Your interior light are controlled by the dial left of the steering wheel. It is s vertical dial and a dimmer for your dash lighting but also will turn your interior lights on and off. Turn it vertically until it clicks off.
Jun 21, 2011 | 1996 Dodge Intrepid
I bought a 96 jeep cherokee sport & the interior lights only come on for the front passenger door. the three other doors & the hatch dont turn on the interior lights & i cant find any fuse box...
Can you turn on the lights with the Interior light switch?. If a light works, obviously the fuse is good. You will need a wiring diagram and a test light to figure out where to start.
Aug 25, 2010 | 1996 Jeep Cherokee
Interior light and radio not working
It's not a fuse, It is the internal wiring, the wiring from your dome light to your wiring harness is bad.. have you recently put in an aftermarket CD player?
Feb 21, 2010 | 2000 Chevrolet Cavalier
My 1978 Chevy Impala loses its charge when I put any load on the car, ie lights, radio ect. I have a new battery and a new alternator on the car, my batter continualy losses it charge and I cant figure out...
most likely wiring around alt or starter any aftermarket radio,amp??? car alarm??? check for open wiring . the alt.can be checked for free at any Autozone.sounds like open wires somewhere or maybe one that is grounding out on the car engine or frame
Oct 04, 2009 | Chevrolet Impala Cars & Trucks
Cut harness from stereo in 1990 corolla dx sedan
did u know that they make a harness for your car that plugs into your factory harness and then adapts to your aftermarket radio? for the lights, you have blown the interior light fuse, it may be the same fuse as the cigar lighter.Below is your radio wire colors and what they do.
1990 Toyota Corolla Car Stereo Radio Wiring Diagram.
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Rear Speakers Size: 4′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Dec 19, 2008 | 1990 Toyota Corolla
Wiring
You installed it wrong... use the manuals.
Jun 17, 2008 | 1992 Dodge Ram 250
Teac AG-V8060 Receiver Logo
176 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
