Question about Magic Chef 31000 Gas Kitchen Range
Majic chef gas range not sure of model #
I have missed placed my range manuel, i have looked for a model# but there is nothing there. i opened the oven door and found these numbers on a sticker #8114p350-60. i purchased the range in 1994 new. the self cleaning broke about the 4th time i cleaned the oven, since then i have cleaned it myself. it is a white stove, gas 4 burner, electronic start, with a black top (clock timer regulator knobs), a black oven door, with a drawer for storage on the bottom. i hope this helps. my problem is that i canot get the oven to work. the 4 burners work great and so does the broiler.when i turn to the oven feature on the dial, it looks like there is a pilot light lit, but it won't heat up. i have sold my home and the range is to remain in the home for the new buyers, but i would like it in working condition before i transfer of ownership.time is of the essence, i only have about 2 weeks to remedy the problem please help thank you
  • 248 Answers
Re: majic chef gas range not sure of model #
You need to replace the oven igniter. It's what you see glowing. They grow weak with age. TURN POWER OFF before servicing this. The numbers can often be found behind drawer at lower front, on oven frame, on left or right near bottom.
Bring model # with you. It should be a standard magic chef igniter. Think it's 12400035.
Remove oven floor to access igniter. It's held on by 2 screws in side of burner. Put some dishwashing detergent on them before trying to remove them. Otherwise they might strip out. The new igniter may plug right in or you may have to cut wires and attach with enclosed wire nuts. The 2 wires to it can be attached either way.
Posted on Nov 07, 2007
0 characters
3 Points
My Majic Chef Oven model CGR3760 is taking a long time to heat up. It took 1 hour to reach 450 degrees! Not sure if this might be a thermostat issue or burner. Penny
Turns out it was the ignitor going bad but not totally gone. We are waiting on a part to come it to replace it. Thanks. By the way, this is a neat service, keep up the good work!
Jan 31, 2010 | Magic Chef CGR3725 Gas Kitchen Range
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven Lights but goes out after just 3 to 5 seconds?
Fixed by brushing vigoursly with a toothbrush and some windex. Allow to dry and restart oven. Works perfectly.
May 01, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
I can't get my oven to go on, keep getting f-7 code on panel
Function key shorted or stuck button Clean and un-stick button or replace Touch Pad or Clock
Apr 11, 2009 | Magic Chef CER3760 Electric Kitchen Range
Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Jan 27, 2009 | Magic Chef 31000 Gas Kitchen Range
here is pretty good link for the might just serve useful.
click here for manual and other info.
good luck.will wait for your comments.
Jan 09, 2009 | Magic Chef 31000 Gas Kitchen Range
Location of pilot light on bottom of an old Majic Chef gas stove
please send model number...and how old in or about years..onthejob
Jan 01, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven not working - strong gas ordor
man that is an old oven, according to the diagram ther is a pilot light in the oven compartment , access form the lower drawer/ cover panel, looks like a pilot for sure and problably has blown out
Nov 25, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic chef oven
look at the burners in your oven,they usually go bad where they plug will look like a peice is missing.if this is not the case one of the wires is loose on you breaker and you're running on 110
Nov 14, 2008 | Magic Chef 31203 Gas Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
553 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Barrett Palumbo
Barrett Palumbo
Michael Thomas
Michael Thomas
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
