Question about Homedics Health & Beauty
Recently I bought the BK 900 massager from thrift store. It did'nt come with adapter. So i plugged a 12V adapter which I had. But it did'nt work. Infact the hand control got hot and there was little burning smell from the control. So I unplugged the adapter and I ordered the PP-ADPEM3 adapter from Homedics for $10. Even with this recommended new adapter, the massager is not working. Did I screw up initially by using a wrong adapter. If so can you tell me a fix for this please? Is there a way to diagonize the problem with the massager. Your feedback will be appreciated.Thanks
I need that adapter (PP-ADPEM3). Not available from Homedics and have never seen it on Ebay. Care to sell it?
Posted on Apr 25, 2012
2 Suggested Answers
SOURCE: Can't disassemble massager.
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Posted on May 25, 2009
I have a Sharp VL-L270U that I bought at a thrift store. I dont have a battery charger and I've tried plugging it into a 12v lead but nothing ever happened. I want to get this thing on and running.
You will be needing a charger that is particularly suited to your device.
There are, out there, hundreds of different chargers, each is different.
Having said that, even if you get the right one, the unit you bought may not work, as it may have failed.
Some thrift stores have a bucket of chargers, but to start, look with a magnifying glass at your unit to see if it will tell you exactly and precisely what amps, ohms, volts, etc. you will need.
Remember too, the tiny plug can be reversed with the positive and negative interchanged, so you must get that right also.
God bless your efforts.,
Apr 05, 2016 | Sharp Video Cameras
Hp touchsmart iq510uk
You can get another one at any computer store, but even much less expensive is at any local thrift or "Goodwill" store that should have lots and lots of used computer stuff very cheap.
Sep 19, 2013 | Computers & Internet
VGP-sp1
just do as I did cut the cable and attach to a store bought power adapter works good. I am only using a 12v power adapter and it seems to work fantastic
May 13, 2012 | Sony Audio Players & Recorders
I need an adapter for the HoMedics model BK-900 massager. Can you give me a model # that will work with this massager?
An easy solution is to order from HoMedics. Copy the following link and paste into a new browser. Fill in the information and they will be able to find you what you are looking for.
Thanks!
Nov 30, 2010 | Homedics Health & Beauty
Need power supply -- what are compatible power supplies?
Take a look where the power-adapter connects into the speakers. Also, look on the "brick" of the power-adapter.
Look for 'AC' or 'DC'.
Look for '6V' or '9V' or '12V' or '18V'.
Look for the Amperage rating.
If 'DC', look for the small pictograms, either:
* ring-positive-post-negative, or,
* ring-negative-post-positive
With that information, check Thrift Stores, and then check the "big-box" computer stores.
Jun 09, 2010 | HP Compaq JBL Pro (401508-001) Computer...
I need to find a source for D-Link Part Number JTA3020A 5V-2A
almost all d-link routers use the same power adapter. All that's important is that it is 5v DC output, and at least 2.0A output current. So you should be able to pull an adapter from another router.
you don't actually need a REAL d-link adapter either, any adapter that matches those specs and fits the plug will work. Just beware, if you plug one in that doesn't match, you'll damage the device. I"ve found adapters like these at the local thrift store all the time.
Dec 04, 2008 | Computers & Internet
Ac adapter
Hi I am an Indian too !
Of course you can use the 220v AC adapter, it will not harm your massager but may only underperform [slow speed, slow vibrations etc]
And be aware that the foreign products you receive, and have adapters rated at 120v are bound to get busted if you use them here in India, don't use them at first place.
Rather, buy an adapter rated for 220-240v for the same output voltage as that of 120v
Jul 12, 2008 | Televison & Video
AC instead of DC adapter connected to Visioneer 7100
The diode on the Power Supply Shorted and Possibly the Regulator also Check the Power Supply areas ttech
Jul 20, 2007 | Visioneer OneTouch 7100 Flatbed Scanner
Health & Beauty Logo
251 people viewed this question
Top Homedics Health & Beauty Experts
Charles T Nevin
Charles T Nevin
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
