Question about Curtis DVD1047 DVD Player
Blinking light on curtis 1047 dvd player
Blinking red light on curtis 1047 dvd player and cant open up dvd player to get disc out.
    Problem Solver:
  • 5 Answers
Needs to be serviced.
Posted on Jun 27, 2009
How do i reprogram my tv remote
Setup codes for RCA tv with this remote control are: 0047, 1047, 1147, 1247, 1347,
1447, 1547
Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
Press and hold SET until the LED (red light) blinks twice,
then release SET.
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
Jun 13, 2012 | One For All URC-4021 Remote Control
Sony dvd recorder repair
try cleaning the disc and reload. i have that problem too. If it's a dvd recorder your disc might have a chip in it which thinks you are trying to copy it . try it on another dvd player without a recorder cability
Jan 11, 2012 | Televison & Video
I have a Vizio TV and comcast cable. I connected the red yello and white to each end, plugged in the curtis 1041d dvd player. The lights come on and the tray ejects and goes back in both manually and by...
there is a problems on the loding sensor swichtes there is two plastic toggle switch inside needs to clean it. used wd40 none static cleaner for electronics devices.
May 30, 2011 | Curtis DVD1041 Player
My Curtis dvd player 1046 won't play dvd's, it says its loading then it says bad disc
First, try playing a regular music CD and see if that works. Next step would be to get a laser lens cleaner disc and run that in the machine. They come in both CD and DVD styles. You most likely won't get a DVD version to work since it's not reading DVDs, but you might get lucky and get a CD version to work, thus the reason for trying a music CD in the player.
If the cleaning doesn't work, or you can't play a CD either, then something has most likely died. There are really only two things that could go wrong with a DVD player, either the spindle motor (spins the disc) dies, or the laser dies. Both are somewhat common problems on low-end electronics. They can be fixed, but with low-end units, like those made by Curtis, it would cost you less to toss it out and buy a new unit.
Apr 05, 2011 | Curtis Televison & Video
Not reading disc
hello,
if your Curtis SDVD9000 9 is not reading any disc, there could only be two problems.
1. the disc you are trying to play might not be compatible and;
2. the lens of the player might be weak;
the solution for the first problem is for you to try another disc,
and for the second problem, you try to clean the lens with a lens cleaner or you replace the lens completely.
take care
May 27, 2010 | Curtis SDVD9000 9 in. Portable DVD Player...
No valid disc
your not using a good disc. use a regular disc and no blue rays
Mar 31, 2009 | GPX D1816 DVD Player
No disc
check ur cd/dvd into other drive if it reads properly then there is the problem dvd player, try cleaning the lens
if it does not work take to service center
Nov 23, 2008 | Curtis DVD8017 Portable DVD Player
My curtis dvd player model number DVD 1047 now only playes in black and white.
Curtis = JUNK. Our Curtis DVD failed after only 3 weeks (Horizonal Hold). The remote was **** from day 1. Replaced it with a Sony DVP-NS700H/B with Multi Disc Resume - WOW - a GREAT feature/ player! Cheapo JUNK is ALWAYS a poor value. Stores that sell **** like Curtis - likely sell other "poor value" JUNK as well - we'll avoid um' like the plague ... Consider it a lesson learned.
Aug 18, 2008 | Curtis Televison & Video
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Curtis DVD1047 DVD Player Logo
212 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
