Washing Machine stops at Rinse Cycle
I am not entirely sure what is wrong with my machine: if I am doing the first wash on that day, it takes a long time to get started and run, and then it just stops and the play/pause button flashes red. I'm not sure which stage this happens at, but I believe it's just before the rinse cycle as the conditioner is not added to the wash. I've tried running separate rinse cycles (which also leads to the button flashing red), and followed by a drain, spin and another drain. It also seems to 'upset' the machine if I'm running the kitchen sink water at the same time. The house I live in is an old one with no central heating system.
It's a brand new machine, so I cannot figure out why it does this.
Please help if you can, many thanks in advance.
  • samarad Nov 06, 2007
    The model is a Zanussi Electrolux Essential.
  • samarad Nov 19, 2007
    Thanks for this - the washine machine repair man came round and opened the valves - as it's a brand new maching there wasn't any build-up, it was just due to the low pressure. your solution was good.
  • 248 Answers
Sounds like a cold water problem. Try running washer set for cold water only. See if it stays running. Most rinses are cold water. If you have low water pressure it can stop due to protection circuit that allows washer to fill for only so many minutes. If it isn't full at end of time span, it may shut down. Try checking inlet valve screens for restriction. Turn off water and remove hoses from back and look into place where you removed hoses. You should see a screen in each one. Scrape out build up with a small screwdriver. Flush out with water.
DO-NOT remove screens to clean. If any debris gets into valve it can cause valve to remain open, flooding house.
Posted on Nov 07, 2007
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ...
    • 6 POSTS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • 14 MIN
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
    Jun 10, 2016 | Washing Machines
    My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
    I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
    Oct 17, 2013 | Whirlpool WTW5700S
    Ge washing machine fills up with water on spin cycle
    Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
    Aug 16, 2013 | Washing Machines
    Kenmore Washer Doesn't Agitate
    Don't be too sure the drive coupler hasn't failed or is failing
    Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
    Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
    SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
    This should clear the machine out.
    Apr 01, 2011 | Electrolux Washing Machines
    My estate washing machine will not spin out, all of the other cycles work correctly.
    Try to clean the magnetic door switch,some windex and a paper towell.Just do the part on the door or lid and where the lid meets the top of the magnet.Make sure this is not loose and is seated in the machine.
    You may need to unplug machine and remove the door switch,take both wires and tie them togther so they make contact.Then try a wash cycle or try the spin cycle.
    The door switches in the estate washers fall apart and get corroded and can stop the spin cycle.
    If the machine works with the switch taken out then you will need to get a new one from whirlpool.
    Mar 25, 2011 | Estate Washing Machines
    Kenmore washer - water won't drain. It stops
    If the water drains between the wash and rinse cycles, your motor and pump are probably OK. If this is a machine with a dial, try a different cycle, like normal instead of heavy duty. If that works and the machine completes the entire cycle then the timer probably has a bad spot. You might try to find a replacement timer if that is the case although I didn't have any luck with my 10 year old washing machine. Best of luck
    Mar 20, 2010 | Washing Machines
    Bosch classixx 1000 washing machine - stops on spin
    Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
    Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
    Aeg 72630 update will not rinse during rinse cycle
    If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
    Jan 14, 2008 | Washing Machines
    Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
    Jul 10, 2007 | Ariston Technologies AWD 121
    Washing Machines Logo
    785 people viewed this question
    Top Washing Machines Experts
