Question about Kenmore HE2 Plus Front Load Washer
Kenmore super capacity washer won't drain. It makes a sound like it's trying to pump out.
  • 15,935 Answers
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
How do I fix a plugged drain on a HE2 plus Kenmore washer.
This is a generic type answer, but, most of these washers have a pump to pump out the water. If some small thing like a hairpin gets in there it will collect lint and plug the outlet of the pump. Or the impeller to the pump may break. Access the pump, remove it, and look for the problem there. Make sure the belt drive to it is working or it will pump no water. I hope this helps. I assume you meant by "plugged drain", that no water is getting pumped out. I have seen this problem in Kenmore washers in the past.
Dec 03, 2015 | Kenmore HE2 Plus 3.6 cu. ft. Front-Load...
Kenmore super capacity washer3.5 not working lights flashes and stops
This is usually a sign that the drain pump filter needs to be dumped or an object has jambed the pump mechanism.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
KENMORE SUPER CAPACITY 3.5 WASHER WILL NOT DRAIN WATER OUT OF THE WASHER?
drain pump is bad or has a blockage will need to inspect drain pump and clear any blockage if clear replace pump
Jan 16, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
My washer is a kenmore, it was working fine the durning the spin cycel made a different sound, I came over afew min later to find water on the floor
could have broke your drain pump it is attached to the motor and the seal there could be leaking, also check your hose's , also your tub seal could be leaking,it's between the tub and tranny. and check your outter tub,could have gotten cracked!
Feb 14, 2010 | Kenmore 3.2 cu. Super Capacity Plus Top...
My Kenmore Super Capacity Plus washer will not drain. I have looked at the hose, I don't think it is the lid close switch and I can hear the timer ticking and then stop right as it should be draining I...
Follow the drain hose inside the machine to the pump, the pump could be clogged. Could have clog in drain hose too.
FYI - Drain hose must be raised in order for it to drain
Nov 12, 2009 | Kenmore Washing Machines
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Kenmore Super Capacity stuck on rinse
Krom, sounds like the machine is syphoning. Check the drain hose and make sure there is a air gap and that it is not too far down the standpipe or drain. To test it hold the drain hose right at the drain top and see if the problem stops...Catriver...post back.
Jan 18, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
149 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
