Question about JVC RX-6010V Receiver
CANNOT GET DIGITAL SIGNAL ON RECEIVER
I connected a digital optical jack between my Blu-Ray player and my JVC RX-6010 audio-video receiver and could get no sound. Also, when I try to access the DVD Digital on the receiver, I get analog with sound or auto with no sound. Note that I only get sound when using regular audio jacks. The digital does not show up. The receiver does not seem to have an input for optical. Could there be a connection issue?
4 Suggested Answers
terribleteac
SOURCE: No Prologic Surround Sound
im thinking the reciever is set to get its audio from somehwere other than the dvd, sounds like you did most of the troubleshooting but do you get audio out of the reciever if its just playing the radio or something other than a dvd?
Posted on Feb 13, 2008
SOURCE: JVC RX-9010V - Setting up Digital Inputs
Just to the left of the volume is a "settings" button. Press it and cycle through the options until you reach "Digital Coax," then use the "Control" up and down buttons to change the assigned source.
Posted on Jul 04, 2008
dunnbiker
  • 8546 Answers
SOURCE: Hi yes i have the jvc RX-8030v and i have a issue
All digital inputs are compatible with any standard physically-compatible audio source. Disregard the labeling of the individual ports. They all function the same. You assign them as necessary. If you have more than one device with only coaxial digital audio you can share it between two sources on the solitary coaxial digital input if you use an RCA Y-cable AND (this is important) only turn one of the source devices on at a time for listening.
Posted on Oct 03, 2011
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
My Blu-Ray DVD player is connected to the AV Receiver with HDMI cable.
You're not going to get any difference using an optical cable. In fact, your receiver cannot look at both jacks at once anyway. If you select an input, it only looks at one jack, it cannot take info from both.
Jan 17, 2013 | Yamaha RX-V673 7.2 Channel AV Receiver...
Do i have to buy a blu-ray player with a coaxial connection to be compatable with the jvc rx e100 home theater receiver?
No, it has connections for optical and coaxial (*) digital audio.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-RX-E100SLC-Receivers-manual/id/315ci068/t/2/
>>>> * A word on coaxial vs spdif (optical) audio cabling - I always use coaxial if I have the choice because it is A) cheap RCA cable available anywhere in any reasonable length you want to run; B) can be extended and SHARED with other components if you have limited jacks available. You just have to be careful to make sure only one digital source at a time is turned on while using the other; C) RCA cable is impervious to problems arising from tight bends; optical physically delicate and won
Mar 21, 2011 | JVC RX-E100 5-Channel Amplifier
Hi, I have a brand new blu ray player, have set it to bitstream, and am attempting to use an optical audio cable, which does not work. The coax analog works fine but cannot get sound. I see in manual...
Instructions from manual
This receiver is equipped with two DIGITAL IN terminals-one digital coaxial terminal and one digital optical terminal.
You can connect any component to one of the digital terminals using a digital coaxial cable (not supplied) or digital optical cable (not supplied).
IMPORTANT:
• When connecting a video component using the digital terminal, you also need to connect it to the video jack on the rear. Without connecting it to the video jack, you cannot view the playback picture.
• After connecting the components using the DIGITAL IN terminals, correctly set the following if necessary:
- Set the digital input (DIGITAL IN) terminal setting correctly. For details, see "Selecting the Digital Input Terminals-DIGITAL IN" on page 16.
- Select the digital input mode correctly. For details, see "Selecting the Analog or Digital Input Mode" on page 17
The rest can be found on the link below. NOTE the page numbers referrer to the manual pages NOT the pages numbers on the site.
JVC RX 5032VSL Instructions Manual Selecting The Analog Or Digital Input...
Nov 10, 2017 | JVC RX-6030V Receiver
Can't connect Digital Optical Audio cable to receiver
The TOSLINK optical connector is almost aquare and should be the same on both blue-ray and on the receiver. There are 4 orientation you can try and only one fits. Blue-ray can have the connector installed rotated, but it should be the same connector.
http://gallery.techarena.in/data/513/thumbs/Toslink-and-Coaxial-Connectors.jpg
Looking at the cable at Amazon I can see that it is the correct cable. If it really doesn't fit, maybe you have damaged cable or damaged connector. Try the other end of the cable and/or other optical input on the receiver.
BTW there is also combined analog/optical jack connector. It looks like normal jack socket, but accepts also optical signal. But this is not called Toslink and usually is not used in home theatre devices.
May 12, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Rx 2700 dts keeps flickering on and off causing
Your symptom sounds like a poor digital connection. The receiver is probably configured to prefer the digital feed if both digital and analog are present from a given source. That it blinks the 'analog' indicator means it thinks the digital signal is degraded.
I believe you're using HDMI. If your cable box has either optical or coaxial digital outputs, try one or both and proceed from there. You could also certify the health of the receiver input that's failing by connecting another device (your Blu-Ray?) to it to test it out, or simply borrow its cable.
If the input works with another device THAT would indicate a problem upstream and external from the receiver - cable, output of the cable box. Optical cables are more finicky than coaxial and do not tolerate being routed in tight radious bends.
DTS isn't Dolby. Read up on it here - http://en.wikipedia.org/wiki/DTS_(sound_system)
Jan 29, 2010 | Yamaha RX-V2700 Receiver
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Dec 29, 2009 | Panasonic DMP-BD60K Blu-ray/DVD Player
No sound from fiber optic 2 jack hooked to a blu ray
IN THE RECEIVER YOU HAVE TO CHANGE THE TYPE OF SOURCE YOU ARE USING (EXAMPLE DIGITAL OPT) AND SOMETIME YOU MIGHT HAVE TO CHANGE IT ALSO IN THE BLU RAY PLAYER TO DIGITAL OPT
Dec 06, 2009 | Audio Players & Recorders
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
JVC RX-6010V Receiver Logo
71 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
