Question about Brother HL 5140 Laser Printer
I have a brother HL-5140 which has some nasty ink spodges on each page. Have carefully cleaned wire as recommended . Is there anything else I can do?
  • 526 Answers
If they are evenly spaced, it will be 1 of 2 things, either the fuser or the drum, if you want to check the drum, take it out, take the toner out of the drum, and rotate the drum by turning the gear, be careful not to touch the drum not have it in direct sunlight or incandescent light and see if you can find the spodges on it.
you can also do a test print, print from the manual tray, and open the main cover after the paper goes in almost all the way. open the door, take the drum out and look at the paper, take it out slowly in the direction the paper was going and see if you see the splodge, if you do, again you will know its the drum.
thanks adi
Posted on Jun 27, 2009
Brother HL 5140 has black specks on the page
There's probably something wrong with the drum unit. I would check the manual on how to change the drum unit. Good luck!
Dec 30, 2011 | Brother HL 5140 Laser Printer
Need to get a total page count or report off of my Brother HL-5140
hold down the "blue GO" button on the printer intill it prints the report.
Have a nice day!
Aug 23, 2011 | Brother HL 5140 Laser Printer
How do you get a page count from an HL 5140/
On the HL-5140, you can print out a config page which will show the page count on it by pressing down the Go button (the blue button). Hold it for a few seconds, until the config page starts to print out.
To find configuration page instructions and page count tips for other printers, copiers, and fax machines, check out How to Print Configuration Pages.
Aug 22, 2011 | Brother HL 5140 Laser Printer
Toner lines horizontally across the page.
Hello, try to clean the transfer wire if that dose not solve U`r problem you will have to replace the Drum Unit.
Jun 09, 2011 | Brother HL 5140 Laser Printer
Our Brother HL-5140 is not printing. It doesn't
Replace the paper pcik-up rolly assembly. MAKE SURE TO get a good look at how the existing one is installed before removing it. It needs a little tweeking to get the new one in and everything lined up correctly.
Also replace the separation page on the paper tray itself.
Look for part number PF-1 Kit or OEM PART #: LJ7920001
The only diagrams I could find on-line of the inside of the printer I found by searching for "brother pl-prn067". Look at pages 8-9.
Dec 09, 2009 | Brother HL 5140 Laser Printer
Brother HL-5140 cleaning page?
There isn't a cleaning page on a Brother 5140. If the smudges are about 3.5 inches give or take a little and the same each time in a line it's probably the drum is damaged. If they are closer like 1-3/8" to 1-1/2" it will likely be the toner cartridge.
If it spaces out a more, something like 2-1/2 it will be the fuser.
Sounds more like toner cartridge though.
Hope that helps you.
Aug 14, 2008 | Brother HL 5140 Laser Printer
Won't print from usb or parrallel cable
check the usb sucket on the printer board and see if the legs are firm if ok check the board
Jul 19, 2008 | Brother HL 5140 Laser Printer
Brother HL 5140 Laser Printer Logo
183 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
