Question about Emerson INSINKERATOR Sink Top Button BLACK STCBLK
I installed this in sink erator Aug. 8, 2003, and today it just does not run when turned on. I pushed the reset button on the bottom end of the motor, and still nothing happens. It is the Badger model with warranty for 2 years. freyv@Juno.com
  • 332 Answers
Does it hummm =, if it just hums it is jammed you need ot take either a alan wrench or the key that comes with the disposer turn off the electric and in the bottom center there is a hole insert the key and move it back and forth till it breaks loose, the remove the key and turn it on,, if it does nothing at all check the wires in the bottom of the unit over time they could have possibly shook off the wire nuts if not tightened properly,,one other thing is to check the switch and make sure there is power to it and going out of it,,
Posted on Jun 27, 2009
Is there a reset button on badger 15ss?
Usually the reset button is located on bottom of disposal near where wire is connected..
Use your hair mirror to look at bottom of disposal.
More disposal resources for troubleshoot, maintenance, repair and installation:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
Feb 25, 2015 | In-Sink-Erator InSinkErator Badger 3/4-HP...
It stopped spinning but the motor made a buzzng noise, then it just stopped all together, now nothing
1) Copy following link for troubleshoot tips and instructions how to install new disposal:
2) Once the motor stops spinning, it will begin to overheat, and that will trip the thermal reset button.
Push reset button located bottom of unit, then rotate disk with broomstick. If motor will not work, then replace unit.
Feb 05, 2013 | In-Sink-Erator InSinkErator Badger 1 1/3...
The reset button is pushed up insie the bottom plate
1) Probably replace disposal, unless unit is still under warranty.
2) Add comment and say what you discover
Feb 01, 2013 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
I just changed my 15 year old Badger 5 as it would not turn on when I flipped the switch. It worked fine for 5 days and then wouldn't turn on again today. What's up?
These motors have aluminum coils that are not secured by winding shellac (short run duration motors) and can break. If you hear a hum but the motor doesn't turn, you can start it by turnning the impeller with a wooden stick. If it starts, the starter winding or switch has failed. (Please make sure your clickson switch on the bottom of the motor doesn't need resetting.) Just exchange it for one that works. It shouldn't have failed this soon. Good luck.
Nov 30, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My waste disposal unit wont turn on
Theres a reset button on the side of the thing.  Also check the breaker box to see if the switch got flipped.
Nov 19, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
No power to in sink erator; washrage chewed up
Sometimes Maufactors Put The Reset Button In The Far Bottom Of The Unit If You Find Button Some Do Not Have One on Them You May Check And See If It Is Wired on Its Own Curcuit It May Have tripped The Beaker In The Main House Service Panel
Jun 30, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In Sink Erator Classic Supreme with sensor problem
I would assume that in the last year you've either fixed the washer or have gotten a new one. If your curious, this is probably the solution. There's a plastic piece that pushed a button when you open the latch and resets the washer. The piece is probably broken. If you remove the screws on the top of the door, you can reach in and manually push the button. You can also tape some metal into the end of the plastic piece so it will still push the button. A flattened bottle cap will work.
Oct 19, 2008 | Dishwashers
In sink erator dishwasher (older modle)
bottom panel loose on one side. cannot push it back in place.
Sep 08, 2008 | Servis 23 in. M4306 Free-standing...
Emerson INSINKERATOR Sink Top Button BLACK STCBLK Logo
223 people viewed this question
Top Emerson Home Experts
john h
Tom Chichester
Are you an Emerson Home Expert? Answer questions, earn points and help others
