Question about Acer Aspire 5335-2257 Notebook
Problem with charging adapter on my laptop acer aspire 5335
It charges and then it wont. When its plugged in, it keeps beeping and keeps going in/out of charging and the charger gets real hot . And basically I do not have my brand new laptop that I cannot even use when its plugged b/c, something is just not connecting correctly inside charger port. If anyone has had this problem & could help me out on how to fix it this little problem that affects the entire lap top, I would really appreciate it!
Thanks Guys!!!!
  • 430 Answers
The charger gets real hot??????? O really? wonder why?....Charger defect... guaranteed
Posted on Jun 27, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
I have an ACER M5-581 and when the battery gets low and I am working on it and I plug it in to an AC outlet and continue to work it will show a charge for a few seconds and then stop charging. I have to...
If the battery is actually taking a charge but it seems the battery only lasts a short time after charging... it's time to buy a new battery. They eventually won't hold a charge very long
Note this is a separate problem then the case where the AC cable is plugged in yet the battery takes NO charge (what happens when the power jack breaks its connection to the computer so NO power reaches computer at all via AC adapter.
http://www.aurabuy.com/cheap-4400mah-battery-for-acer-travelmate-8473t-8573-8573g-8573t-4370-5335-5340-7340-tm5742-4740z-8573tg-5742z-paypal.html
Mar 31, 2013 | Acer Aspire One PC Notebook
Acer aspir dc jack repaired now it will not charge. do i need a new charger or battery
Go into devices manager and see if your battery drivers are installed,windows needs them to know there is a bettery there to charge it.You should see them on the first of the list...good luck:)
Apr 13, 2010 | Acer Aspire 5335-2257 Notebook
The ac adapter for my Acer laptop has a continual beep in it and is no longer charging the battery.
Remove the laptop battery / plug in to mains, if beeping has stopped, faulty battery. If not then charger or mains faulty.
Feb 08, 2010 | Acer Aspire 6920 Notebook PC
My Acer Aspire 5735z battery won't charge!
Your adapter port might have been improperly adjusted. Jiggle the cord around in there while it's plugged in to see if the plugged in light comes on. If it does then that's your problem. You can prob things under it to keep it at that point for a quick fix but I'd recommend a local computer shop for repairs.
-CompDoctor
Feb 01, 2010 | Acer Aspire 5735 Notebook
I have an Acer Aspire 3610 notebook. It wont charge
How old is your battery? When you use your laptop, do you run it on just the battery or do you use your a/c adapter and battery? If you're going to use your laptop for an extended period of time, it's recommended to remove the battery and run off of a/c power alone. This helps to extend the life of your battery. Over time, using both a/c and battery will cause your battery to charge/discharge, which dramatically shortens the life of the battery.
You may simply have a dead battery.
Another alternative is that you have a bad power unit, which is what the a/c adapter plugs into on your laptop. My guess is that you most likely have a dead battery.
Oct 07, 2009 | Acer Aspire 3610 Notebook
Ac adapter connection inside laptop doesnt work, light for battery charging will not turn on and will not charge
You adapter may be faulty, check it with a multi-meter, the voltage reading for a functioning adapter should be slightly higher than the voltage that is printed on the label on the adapter.
If you do not get a voltage reading then the adapter is faulty and you need to get a replacement adapter.
If you get a reliable voltage reading at the adapter plug, then connect it into the laptop and wriggle this plug. If the charge LED blinks. then the power connector on the laptop is loose/faulty and needs repairing.
Apr 14, 2009 | Acer Aspire 5570-4820 Notebook
My acer is plugged it but will not charge
if the adapter charge the battery but cant keep the lappy power up thereis something rong with your motherboard. to test take the battery out plug adapter in turn lappy on. if it does not power on motherboard problem
Apr 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Open Questions:
acer aspire 5335-2257 replaced 4 pin power jack intermittent power, only runs with battery but barely charges. acer aspire 5335-2238. My son's friend recently asked me to take a look at his laptop because he couldn't get it to take a charge or run without the battery when plugged in. Right away I noticed the dc jack was charred and the plastic around it melted. He said the power cord "brick" got really hot, all the way to the tip where it plugs into the laptop. I know the bricks can get warm but he said it actually burned his sister. I ended up replacing the dc jack and 4 pin harness with a new one and figured this would solve the power issue. It won't get power with the original power cord and I also tried a few others that were similar. The only one that worked was an adaptor that I think went to a cordless phone or something like. The next problem was I had to fiddle with the dc jack to get the yellow battery light on. Still won't turn on without battery. The battery at this point is drained so I left it plugged in all day, at least 12 hours and the green light finally came on indicating a charged battery. The battery only charged about 8-9% and died fast. I tried more adaptors and got another one to light up the yellow battery light, again a small modem adaptor, not one with the brick. This time I left it over night and got about 12% charge. Both times the laptop turned on, booted up and ran until the battery died after about 5 min. I'm out of ideas aside from maybe a bios problem but I can't get it to stay on long enough to do anything about it. I don't understand why the new jack isn't working, it's a pretty simple install, no soldering. I looked real close at the board and didn't see any obvious fried chips or anything like that. Any suggestions would be great. I've had this 14 year old kid's laptop for almost 2 weeks trying to figure it out (I also replaced his keyboard, disc drive and cleaned it up) and he's calling me every day.
Feb 27, 2017 | Acer Aspire 5335-2257 Notebook
Acer Aspire 5335-2257 Notebook Logo
444 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
