Question about Belkin Computers & Internet
Cant get wife to connect is the wireless icon
Cant get wifi to connect is the wireless icon supposed to be lit up on the router?
  • 390 Answers
Hi
no the wifi stay blinking on activity, but the wireless connection on the laptop has to stay on
1. first have you tried with the ISP if you need any Proxy settings or specific IP address.
2. also check with the ISP if you need any specific DNS server settings
3. if the above two are given or not required but the router still does not give out connections then try this
instead of connecting the cable from the Modem to the slot named INTERNET try connecting it in one of the out going slots (numbered 1,2,3,4) and now connect the other systems as usual.
cheers
PS: if this has been any bit useful pls rate it, thanks
Posted on Jun 27, 2009
My wifi is always white so I cant use my google play store...How can I make it turn green??
In the settings you need to choose connect to WiFi and then pick your wireless router. If you don't have a wireless router, you won't be able to login to the net.
You could try to login on a free hotspot like with Starbucks or Mac Donald. But as soon as you are 10 feet away from the building you won't have Wife.
Jul 12, 2014 | Tablets & eReaders
Cant get my laptop to connect to my wifi
make sure the wireless adapter is enabled. You can do that by right clicking the monitor icon on your lower right side of the tool bar...unless you use a MAC. Then look for connections. Some devices have a lock slide that needs to be turned on to use wireless adapter and/or even have a wifi button you can press. Is your laptop not recognising the router?
Aug 26, 2013 | Motorola Computers & Internet
I cant connect my ds to router
you may need to manually input the ip adress or MAC of router in ds. on on your cpu, you can look up your router and its properties, record ththe type of securtiy or encryption, the pass word, mac address and ip address .
On ds, check to see if ip auto config is enabled or DHCP enabled. if after scanning and connection faills, manually configure wifi settings to mmatch those found earliear on your cpu running the router, entering the mac, ipaddress ect. also be sure you are not to far from the router and the wife switch is turned on somewhere on side of unit so the wifi arcs symbol is iluminated or lit up
Jul 13, 2012 | 2wire Computers & Internet
I have installed, set up, and created my router's name, password, and key, but im still having trouble connecting to the internet. The little icon that looks like the earth is glowing orange, and the only...
Use the network setup wizard to connect to your network, and the internet. Unless you did this already.
You can get the wizard from Control Panel, Network ... , Connect to a Network. If wired you won't need key, it's for wireless only.
Yo did not say what OS, so info is a little generic.
Hope this helps.
Jan 26, 2011 | D-Link DIR-615 Wireless Router
I have a new laptop with wireless at home. How do I set up the wireless connection from my zonet router? Victor
By default, wireless routers always broadcast wifi signal. The only thing you need to do is to enable the wifi radio receiver of your laptop. To do it, make sure that you have the wifi LED lit in your laptop which means that your wifi receiver is ON. Now, you need to connect your modem to your router so that your router will then broadcast internet signal. Then you are good to go. Your laptop should get connected automatically and receive internet signal.
If you want to configure your router, visit http://192.168.1.1 when you are connected to the network so that you can change some of your router's behavior.
Dec 10, 2009 | Zonet ZSR1104WE Wireless Router
So i have my desktop set up online, but i want to get my laptop hooked up as well and i have a router. how do i hook that up to?
On the right bottom corner of your screen, you should see a message/icon about wireless networks.
Select the icon and you should see a list of wireless networks. Select your network, add your password (if you set up a password) and you should be connected.
Open your browser.
Hope this helps.
Sep 08, 2009 | NetGear WGR614 Wireless Router
Wireless router
You may need to turn the WiFi card on. Many Laptops allow you to turn the cards off to save power. Look for a button acros the top of the keyboard or on the side whick may have a WiFi logo or a little aerial icon.
Mar 18, 2009 | Linksys Wireless-G WRT54G Router
Configuring WRT54G
there are many ways to setup/configure a wireless router. the easiest way for me is to plug your modem to the router, (even though unplugged, there should be a wireless network signal on your device that has a wifi but no internet connection) once connected, plug the modem to the wireless router then reset it, wait a few seconds then you'll get an unsecured network with internet access on it. usually, the only use for the cd is to make you configure it easier like putting a password on it etc.
Feb 05, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection
by default, dell systems' switch for wireless can be done by pressing Fn and tap F2. The wifi light should lit up. Your modem is integrated to the motherboard. If you were able to lit up the wifi light, this should be able to detect wireless signals for you to connect to.
Sep 19, 2008 | Dell Inspiron 2200 Notebook
My wrieless network connection is properly installed but i can not connect internet using my laptop
Dear Ditditong,
First is your wifi switch on the compaq enabled. It is suppose to be lighted and an icon on the task bar will tell you it is.
Second, check your Wifi OS set-up if properly done ; if not use the windows wizard to accomplish this.
Third, Make sure your D-link has been properly set-up for wireless set-up to be able for you to access the router. The manual might have information along this line.
Sidlahora
Jan 26, 2008 | Computers & Internet
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
