Question about Acer Aspire 5610-4648 Notebook
Acer 5610 can barley see an image on screen/ tried a stand alone monitor with same problem.. is my isse video card related
Did a complete wipe of the hard drive and reinstalled XP and still have t he same issue...It is starting to make me think the lamp is what is out or going out .
Posted on Jun 27, 2009
  • 430 Answers
Yessss.....do a restore till when it was fine....or reinstall video driver....u decide GL
Poweredge 6600 not showing display
If you have multiple video connections (onboard from motherboard, usually vertical or stand alone video card, usually horizontal) that you plug into the stand alone card, as the onboard is normally disabled when the expansion is installed. Verify the cable and monitor both work and that the monitor is on the correct input. Finally try another video card, if you have one available. Even if the drivers are not correct, etc, you should still see a boot screen.
Nov 13, 2013 | Dell PowerEdge 6600...
Acer AL1917W LCD monitor powers up but no image at all.
The CPU and PSU, have absolutely nothing to do with a monitor.
HERMAN has the correct response. For the info you posted.
When you have a video problem, you post what the motherboard is or what model PC, the graphics card, and what drivers you have installed.
Aug 07, 2012 | Acer AL1917W LCD Monitor
I hav a asrock p4i45dv mother board , its cpu lights appear but nothing is displayed in monitor may i know the cause of this problem and soluton
This is either a bad monitor, a bad video card (if you're using a stand-alone card), or a bad motherboard. Test the monitor by connecting it to another computer. If the monitor works, then it's the video card or MOBO. Use a stand-alone (PCIx/AGP) video card that you are certain works. If this does not work, then the MOBO is not working. I hope this is helpful and best of luck!
Sep 21, 2011 | Asrock P4I45GV R5 Motherboard
When I try to start my VGC-RB30 (back from sleep mode or fresh start), computer comes on, but monitor doesn't (or I get the VAIO screen only). Yesterday, I unplugged the computer altogether, then plugged...
Check all of your adapter cards (PCI or AGP or PCIE) to ensure they are seated into the MB properly. As the problem seems video related double check the graphics adapter if it is a stand alone card. AGP cards can be tricky to seat properly on some mb's
Jul 07, 2010 | Sony VAIO RB30C (VGCRB30) PC Desktop
The Computer was working just find then the video just quit working an won't come on. It is a onboard video card.
The first thing to check is the monitor. If able, plug the monitor into another machine to verify the monitor is good. If the monitor is good I would recommend trying a stand alone graphics card. If the video then works with a stand alone graphics card, then the on board video is probably bad. If the latter is the case then you can run the stand alone graphics card but the motherboard is probably on its way out. If the monitor does not work on another machine, it is most likely swollen capacitors or transistors on the inside of the monitor. If this is the case repair or replace monitor.
Jan 02, 2010 | Dell XPS 200 PC Desktop
I have a aspire 5610 , the problem is when the laptop coming up just showing windows logo and after that nothing , i did try with monitor and thats showing same thing , i want to know the problem is with...
If you are seeing the same thing on your Notebook screen and an external monitor then it is most likely NOT the monitor, and VGA would be more suspect. Before doing much else though, right click a blank spot on your desktop and click "Personalize"; go through the various video items there to try to make things more useful. Let me know, OK?
Dec 02, 2009 | Acer Aspire 5610-4648 Notebook
I'm also experiencing same sort of white screen problem.
To determine if the LCD screen or the video card is faulty, connect an external monitor to the video connector on the laptop. Power up the external monitor first and then the laptop. The video should divert automatically to the external monitor and if you get a normal image then the video card is OK and the fault could be the LCD screen or the video cable. Reseating the video cable and connector on the motherboard could fix yout problem.
Jun 14, 2009 | Acer Aspire 4315 Notebook
Monitor issues Acer 5610-4621
sounds like a bad video card honestly. I doubt the monitor was bad.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
Lcd not working
You could have a faulty video card, or a faulty inverter, (this supplies high voltage to the CCFL lamp), or a faulty CCFL lamp.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 18, 2009 | Acer Aspire 5610-4648 Notebook
MY ACER LAPTOP SCREEN TURNS ON BUT THE SCREEN IS BLACK
To determine if you have a video card problem or the LCD screen is at fault.
Connect an external monitor to the video port on the laptop and boot up your laptop, if you get a display on the external monitor then your video card is OK and you have a faulty LCD.
When you power your laptop without an external monitor and have a close look at the LCD screen at and you see a slight image then the fault is with the backlighting panel. This fault could be a faulty inverter or a faulty CCFL backlight lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
The inverter can be easily replaced so can the CCFL lamp (but requires a lot more work)
For info on parts and repair service goto www.lcdparts.net
Mar 02, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610-4648 Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
