POWER SUPPLY UNIT
Whenever I switch on my PC after sitting idle for long hours without any electric current passing through it or connected to my power outlet, most of the time it doesn't turn on immediately. I had to wait for a few a minutes while the voltage regulator is turned on. After that I switch off & on again my voltage regulator and only by that time my PC starts to operate. I suspect that it could be my 230 - 300 Volts PSU but it might be also the voltage regulator. Can someone help with with this dillema?
  • Anonymous Apr 28, 2008
    After powering I have to wait for ten minutes before it comes on. The two green lights are lighting inside the mother board. Suspect a capacitor!!
    Novelist:
    Champion:
  • 254 Answers
A voltmeter would be helpful here. If the proper voltage is being supplied to your computer power supply, then the computer power supply itself is defective. You could use the voltmeter to verify this, or just merely bypass the regulator- plug the computer directly into wall current, assuming here your wall current isn't terribly out of tolerance, or terribly dirty - spikes, sags etc.
I have seen several computer power supplies which are slow to come on. The problem is often electrolytic capacitors in the power supply circuitry - probably in the standby +5 volt supply (this powers a tiny part of the circuitry on the motherboard). The voltmeter could be used to check this out also.
If this is the problem, it will likely get worse, to the point where it won't power up at all. Whether you want to replace the capacitors, or just swap out the p.s. is up to you. If the p.s. is a high quality unit, repairs might be suggestable, especially if you have some technical skills.
Posted on Nov 07, 2007
    Novelist:
    Champion:
  • 231 Answers
Hi, you can almost bet anything that your voltage regulator is at fault. It sounds as if this needs time to build enough resistence to reach the 240 volts required by your computer's PSU.
Change this unit and you should cure your problem.
Question, Why do you need to use a voltage regulator?
Are you running on home generator power?
If you run on mains regulated power then replace the voltage regulator with a power surge protection board.
Regards mistyman
My nuvi 260W displays the computer plug in sybole then turns of both while move and sitting still an d is connected to power supply. I have bought new connector for power supply.
Whenever you see the computer to GPS symbol pop up while using the DC car charger, this is an indication of a loose USB jack (bad connection) between the jack and the printed circuit board.
You should only see this symbol when connected to the PC using the USB cable. You should never see it when using the charger. Please see this link for more information and how to have it repaired:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Apr 09, 2014 | Garmin nuvi 260W GPS Receiver
My DVR 433H-K DVD recorder has a problem : the power shuts down and switch back on automaticaly without pushing any button. what's the cause and how can i solve the pronlem?
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
This will help in solving the problem...
Aug 08, 2011 | Pioneer Televison & Video
Connected to pay TV.Picture goes off but sound remains.Switch TV off and after 20 seconds most times picture returns.TV is Phillips Cineos 6 yrs old
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Take care in solving the problem....
May 10, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
DELL TV MODEL #W3201C KEEPS TURNING OFF BY ITSELF AFTER A FEW HOURS OF USE.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
I hope this will help in solving the problem.......
May 07, 2011 | Televison & Video
My tv just stopped working. When i felt the power supply box it was very hot. I unplugged the tv and after half an hour turned it back on when the power supply cooled down. The tv worked again but only...
It's the problem of overheating in the power supply board of the Television.on the power supply board of the Television there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the Television the current passes from electric outlet to the power supply board of Television.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and Television shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop television
This will help in solving the problem.....
May 06, 2011 | Televison & Video
Have an electric run pellet fire what size car or truck battery to run for 8 hours 520 watts
You'll need a 600W (Minimum) 12 to 240V Inverter as in the link below.
http://www.powerinverter.co.nz/16-10-12v-to-220v-power-inverter-600watts.html
As for the battery you will need 44Amps of Battery Power for every hour you want to run the equipment (this is without any losses from the inverter on inefficiency from the battery). You would therefore need as a minimum 2 x 200Ah 12V Batteries connected in parallel for something like your 8 hour duty. You'll also need them to be this sort of size so that they can supply the high current for a long duration. i.e. a 44Ah Battery would not supply 44Amps for 1 hour.
Hope this is OK and please leave feedback.
Cheers
Andy
Apr 30, 2011 | RaidMax ( RX-520XP) 520-Watt Power...
Hello The problem I have with my TV is that sometimes it switches itself into standby mode without me pressing any buttons on the remote, then when I switch it back on using the remote the screen...
Its the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this help in solving the problem, Take care.....
Sep 13, 2010 | Televison & Video
Freedom 20 stops passing good AC input after about 15 sec.
This unit does have an idle mode where it will not output without a load. What I am unsure of is if this exists only for invert mode or for both invert and pass through. Try reprogramming the remote to eliminate the idle feature and then see what happens.
Jul 30, 2009 | Xantrex Technology Heart Freedom 20 12...
Yellow light at mains inlet on when computer switched of and mains disconnected
I am not sure exactly what is meant by mains inlet. However if you mean that you disconnect the power from the computer after it has been turned off and and there is a light on the computer indicating power is coming to the computer, there is a perfect explanation for this.
Your power supply in your computer, along with your computer's motherboad both have capacitors on them. Capacitors hold electrical current. They are placed in the path of electrical current so that when an electrical current passes through a capacitor if the electrical current is too strong it stores some of that current in the capacitor. If the electrical current is too weak it provides the needed amount of current. So basically a capacitor serves to equal out an electrical current when needed. The capacitors in a power supply are pretty big (about the size of a D Cell battery), and hold alot of charge. Infact it is never a good idea to touch one of these large capacitors cause they will release their charge into you, and they can be quite dangerous.
I said all that to say this: When you unplug your computer those capacitors can still supply a little bit of electricity to your motherboard and cause your computer to show that it is still receiving power. It is perfectly alright for this to happen.
I do believe that this may have been what you are referring to, I hope this helps to answer your question.
Sep 20, 2008 | HP Computers & Internet
Power supply gigaset 8825
The power supply for the 8825 base is to be 13 volts AC, rated at 850 milliamps or higher. You can go anywhere from 13 up to 15 volts without hurting the unit, and a higher current rating is even better. We actually make them ourselves through bulk purchases of varieties of power supplys. Your next delimma will be the plug size, it is a pretty common size, most universal adapters will have the right size of the outer and inner connections.
Nov 16, 2007 | Siemens Gigaset 8825 Cordless Phone
Computers & Internet Logo
214 people viewed this question
David Payne
David Payne
