SOURCE: Panasonic Kx-t7456 digital super hybrid system time setting question!
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
SOURCE: Change Time
Press 'Prog' then press star key twice, then enter '1234', then enter '000', will get you to Date & Time Set, then press 'enter' button (bottom right hand corner of phone), this will then allow you to change the date and time accordingly.
Hope all goes well
Tess, Australia
SOURCE: Change the time and date on Panasonic KX-T7730
You have to change from extension 101. Once you are on extension 101 then you need to press program then 0. enter date backwards ie(081104) then day (1=mon 2=tues 3=wed 4=thur 5=fri ect.) then enter time ie(0300 for 3:00) then 0 for am or 1 for pm. so it would go like this
Press program then 0
Enter (example for Tues. Nov. 11,2008 3:00 pm) would be
081104 2 0300 1
then press store then program again and it's set.
SOURCE: HOW DO I CHANGE THE TIME ON A PANASONIC KX-T7730
If you are using the KX-T7730 phone with a Panasonic KX-Txx 308/616/824 system. From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done.
Please rate this answer if it was helpfull.
Thank you.
SOURCE: How do I change the time on my Panasonic phone
The Panasonic TD phone system has been manufacturer discontinued for at least SEVEN years. In all that time, you never learned how to program the time?
From the book. Go to the Manager or operator phone. Press PROGRAM **1234 and dial 000.
It will let you use the FWD button to step through the date and time. Key in the numbers and press STORE.
Pick up and drop the handset back in the cradle to exit programming.
Carl
