Question about HP OfficeJet J4580 All-In-One Laser Printer
We have no manual for this printer and cannot turn it on. Help!
We see a power switch on the left at the top, but nothing happens when we press it. There is a flashing light that looks like an exclaimation point on the right. We are unable to get the printer to operate.
    President:
  • HP Master
  • 566 Answers
Before connecting the printer, you must install the drivers and software that came in a Cd when you bought it.
Check the HP site for drivers, information and manuals for your printer.
If can find them here:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3645100&lc=en&cc=us&dlc=en&dlc=en&lang=en&cc=us
Posted on Jun 27, 2009
XEROX 5330 ERROR 116-312
make sure printer is off,
turn Main Power off as well,
1. turn on power switch on top, but leave Main Power off
2. while having the top switch on, turn on the Main Power switch and at the same time press 6 continues times bottoms (#4, Energy Saver, Stop) or until you see boot mode hdd format mode on your left corner let go and waiting till is done and ready.
Feb 04, 2014 | Office Equipment & Supplies
Print carriage access door is open or ink cartridge cover is open. getting this message but nothing is open!! It says to hold down ok button for 5 seconds but nothing is happening. I turned off but it...
Turn off your printer
Open the cover
1 move the cartridge carrrier manually to the center manually with your hands from left torgiht ( 5x )
2 .Remove the cartridges used a clean paper make sure its dry wipe the area where the ink goes out make sure its clean .CLean also the area where you return your cartridges make sure its clean OK .
3 >return it properly close the carrier properly make sure there's a snap sound produced .Move again the cartridge carrier manually from left to right 5x
close thecover
try to turn it back on
in case nothing happens
remove all the parts cartridge ,black box paper power supply
lift the printer up turn it up side down make sure the cover is open when you lift it up and turned it upsidedown
so any foreign material will come out
Shake it for 5x
\return all the parts
try to power it on
Hope it help thanks
May 26, 2011 | HP Officejet Pro L7680 All-In-One Printer
My HP 3210 all-in-one printer does not power up when I plug it in. It appears to be getting power because when I plug the printer in, the little bluetooth light in the front lower right does light up. ...
Are you taking it off electricity a log? If so you have to set it up to your preferences sometimes. And are you tapping the "on" button at far left at the top? It should work. But it must be plugged in of course and the button has to be pushed. Don't push too hard or too long or it will turn off.
Aug 06, 2010 | HP Photosmart 3210 Printer
E,3 flashing on Canon MP140
http://www.devicemanuals.com/model/Canon_PIXMA+MP150_manual.html
How to reset printer canon pixma MP150
  1. When you turn off the printer, then click STOP / RESET and the printer knopkuo POWER.
  2. Without releasing the POWER LED lights up when the power button, press 2 times STOP / RESET
  3. Release the power button, and then a second button - you hit your profile.
  4. The indicator light green. Press STOP / RESET 4 times.
  5. Turn off the printer.
http://tricks-collections.com/reset-canon-pixma-mp150-mp160-mp170-mp180-mp450-mp460-mptool-software/
http://www.klinik-printer.com/2010/02/canon-pixma-mp150-service-manual.html
Service manual above, above that a repair site, above that is a forum for help, above that is your user manual
May 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How to change a fuse in the hp 2800 printer, power up problems
There are 2 fuses inside the power supply unit.
The hard part is getting to the power supply! The power supply is located at the left side of the printer and in the front (the opposite side of the cartridges).
You have to remove the side and top covers.
There are some hidden screws. One is under the button faceplate that you will also have to remove. The entire procedure is tricky especially without a service manual. Unfortunately I couldn’t locate a manual.
Caution always disconnect the power lines and allow some time for capacitors discharge before you attempt any repairs.
I hope you have some luck with yours !!
Nov 13, 2009 | HP Business InkJet 2800 Printer
Dead sharp pc-ax40
You can try reseating the memory and the hard drive if you can get to it, but it sure sounds as though the motherboard is shot.
You can take it to your local computer repair shop.
Good Luck.
Mar 15, 2009 | Sharp Computers & Internet
I had a paper jam and when cleared,
What happens when you power off/on the machine?
Inkworks
866-381-0541
Nov 01, 2008 | HP DeskJet 5650 InkJet Printer
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
970 Cse cartridges bang over to the left and then nothing
I had the same problem with my HP Deskjet 970Cse which was quickly resolved by going to the below HP site and looking under the Issue: The carriage is stuck or makes a grinding noise. Note that the blinking lights displayed as: Resume Light Blinking Simultaneously AND Power Light Blinking Simultaneously.
The Solution:
1. Lift the top cover to the printer.
2. Turn the printer off and then on again.
3. Unplug the power cable from the back of the printer when the grinding noise starts.
4. Move the carriage towards the middle of the printer.
5. Take out the cartridges and close the top cover.
6. Plug the power cord to the back of the printer. Turn the printer on.
7. Open the top cover, reinstall the cartridges, and then close the top cover.
Hope this helps as it worked for me.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09170&lc=en&cc=us&lang=en&product=60097&dlc=en
Jan 11, 2008 | HP DeskJet 970cse InkJet Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
