Question about HP Media Center PC M260n (DF200A#ABA) PC Desktop
Error 2: the system can not find BITS
Error 2: the system can not find the file for Background Intelligent Transfer Service
    President:
  • 1,257 Answers
GET YOUR PC PROBLEM FIXED
http://www.windowsguru.org
Posted on Jun 27, 2009
Why is my computer cant download adobe flash player?
If automatic updates also don't work Google "background intelligent transfer service". I had the same problem and it was because BITS was turned off. Beyond that, I don't know.
Jun 22, 2011 | Cycling
Three users of Outlook 2007 shut down their computer and the next time they turn them on, they get the error message "A data file did not close properly" in Outlook and Outlook check's its...
Are you using any trend micro anti virus? If so, try the following
1. Open your Outlook 2007
2. Click on Tools.
3. Click on Trust center.
4. The Trust center window will pop-up and click on Add-ins on the right part of the screen.
5. Under Manage: COM Add-ins
6. Click on Go.. (Middle bottom part of screen)
7. Uncheck all the Add-ins Exept for TMAS (TMAS is Trend Micro) then Click on OK.
7. Restart your computer.
Or if using a anti virus program and you see that in the "add in" options just substitute.
The following link has some problems and solutions for that event ID you gave.
Click here
Regards,
G33k
May 05, 2011 | Computers & Internet
When i tried to to install service pack 2(twice) it downloaded to 24% and stopped . With the error code 8E5E0442 windows update encountered an unknown error .
Perform the following steps to reset the Windows Update component.
1. Stop the Background Intelligent Transfer Service and the Automatic Updates service. To do this, follow these steps:
a. Click Start/All Programs/Accessories. Right click 'Command Prompt' and select 'Run As Administrator'. Click 'Continue' on the UAC prompt.
b. At the command prompt, type the following commands, and then press ENTER after each command:
net stop wuauserv
net stop bits
2. Rename the "Catroot2" folder. To do this, follow these steps:
Type the following commands, and then press Enter after each command.
net stop cryptsvc
ren %systemroot%\System32\Catroot2 oldcatroot2
net start cryptsvc
3. Rename the "SoftwareDistribution" folder:
Type the following command, and then press Enter.
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
4. Register the files that are used by Windows Update and Microsoft Update. To do this, follow these steps:
a. At the command prompt, type the following commands, press ENTER after each command, and then click OK every time that you receive a verification message:
regsvr32 wuapi.dll
regsvr32 wuaueng.dll
regsvr32 wucltux.dll
regsvr32 wups2.dll
regsvr32 wups.dll
regsvr32 wuwebv.dll
5. Start the Background Intelligent Transfer Service, the Automatic Updates service, and the Event Log service. To do this, follow these steps:
a. At the command prompt, type the following commands, and then press ENTER after each command:
net start bits
net start wuauserv
net start Eventlog
exit
Reboot the computer and try Windows Update again. That should get update working gain but your update status may change a bit so you may have to rerun update a few times.
Mar 04, 2011 | Computers & Internet
My note book starts too much slowly and mostly stucks it takes about 2 or 3 min to the starting window screen and 2 min in the welcome screen. kindly tell me the solution
It might be due to Virus.So please use a anti-virus software and try scanning the virus
To my knowledge , if you have just updated , you should be OK , MS say they have have fixed all their faulty patches .
Did you download all the security fixes ?
Here are some other things to try .
http://www.techspot.com/tweaks/winxp...rvices-3.shtml
http://www.techspot.com/tweaks/winxp...es/index.shtml
http://www.techspot.com/tweaks/wfp/index.shtml
If your system hangs about 2 or 3 minutes at startup, where you can't access the Start button or the Taskbar, it may be due to one specific service (Background Intelligent Transfer) running in the background. Microsoft put out a patch for this but it didn't work for me. Here's what you do:
Click on Start, Control Panel, Administrative Tools then Services.
Go to the 'Services' tab, find the 'Background Intelligent Transfer' service.
Disable it, apply the changes & reboot.
Or if you don't want to disable it .
Background Intelligent Transfer Service. Uses idle network bandwidth to transfer data. For the majority of Users this feature should be of little use & as such I'd recommend setting it to Manual. Those on highly active Networks may benefit from having this set to Automatic, although it may be worth testing out to see if it does.
http://rogier.xszone.nl/windows/wintricks.html
• Defragment boot files
The boot defragment option is usually enabled by default, but it may be disabled, or not properly enabled. If it's not working, XP may boot dog-slow.
To enable it:
- Edit HKLM\Software\Microsoft\Dfrg\BootOptimizeFunction, find the string called Enable. If the string value is set to N, change it to Y.
http://support.microsoft.com/?kbid=308041
Resources for Troubleshooting Startup Problems in Windows XPmag-glass_10x10.gif
http://www.blkviper.com/WinXP/servicecfg.htm
http://www.blkviper.com/WinXP/servic...#Network%20DDE
Enable Quick post in BIOS setup , as long as you have a have a lot of memory .
The normal memory test , is tested three times & that alone may take 60 to 90 seconds.
http://www.windows-help.net/WindowsXP/troub-07.html
http://www.tweak3d.net/tweak/winstartupnew/
Disable the Windows XP Prefetcher
Windows XP has a Prefetcher component, which shortens the amount of time it takes to start
Windows and programs. When trouble shooting either Windows or program start-up issues, it might
be helpful to disable the prefetcher, because it runs as a background service while other
applications are running or loading.
To disable the prefetcher:
Start the Registry Editor
Go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ SessionManager \ Memory Management \ PrefetchParameters
Double-click the EnablePrefetcher value (remember the value that EnablePrefetcher is set to!)
Change the Value data to 0 to disable the prefetcher .
Close the registry editor and reboot the computer for the changes to take effect
When done troubleshooting, you can re-enable the prefetcher by changing the Value data to its
original value.
Values for EnablePrefetcher are:
0 - no prefetch
1 - prefetch applications only
2 - prefetch boot only
3 - prefetch both applications & boot (default)
I find 5 is best .
THANKS......
WITH REGARDS........
VAISHU
Sep 26, 2010 | Dell Inspiron Mini 10 Notebook
Why can't I download windows service pak 3 on my dell laptop. Referenced memory error the memory could not be read.
To resolve the issue, follow the steps mentioned below:
1) Click on Start, Run and type the following command in the open box and click OK.
services.msc
2) Find the Automatic Updates service and double-click on it.
3) Click on the Log On Tab and make sure the "Local System Account" is selected as the logon account and the box for "allow service to interact with desktop" is UNCHECKED.
4) Under the Hardware Profile section in the Log On Tab, make sure the service is enabled.
5) On the General Tab, the Startup Type should be Automatic, if not, drop the box down and select Automatic.
6) Under "Service Status" on the General tab, the service should be Started, click the Start button enable it.
Repeat the steps above for the service "Background Intelligent Transfer Service (BITS)"
Jul 06, 2010 | Dell Inspiron E1505 Notebook
HOW TO FIX ERROR CODE 80070057
See: http://support.microsoft.com/search/default.aspx?query=80070057
for 347(!) different suggestions from Microsoft on how to fix the problem.
Dec 30, 2009 | Microsoft Windows? Vista Home Basic...
Application Error
How to Repair this SVCHOST.EXE error
After some investigating into the 0X745f2780 SVCHOST error, it became apparent the problem is a corrupted Windows Update in Windows XP. Follow the steps below to fix this error.
Verify Windows Update Service Settings
  • Click on Start, Run and type the following command in the open box and click OK
    services.msc
  • Find the Automatic Updates service and double-click on it.
  • Click on the Log On Tab and make sure the "Local System Account" is selected as the logon account and the box for "allow service to interact with desktop" is UNCHECKED.
  • Under the Hardware Profile section in the Log On Tab, make sure the service is enabled.
  • On the General Tab, the Startup Type should be Automatic, if not, drop the box down and select Automatic.
  • Under "Service Status" on the General tab, the service should be Started, click the Start button enable it.
  • Repeat the steps above for the service "Background Intelligent Transfer Service (BITS)"
Re-Register Windows Update DLLs
  • Click on Start, Run, and type CMD and click ok
  • In the black command window type the following command and press Enter
    REGSVR32 WUAPI.DLL
  • Wait until you receive the "DllRegisterServer in WUAPI.DLL succeeded" message and click OK
  • Repeat the last two steps above for each of the following commands:
    REGSVR32 WUAUENG.DLL
    REGSVR32 WUAUENG1.DLL
    REGSVR32 ATL.DLL
    REGSVR32 WUCLTUI.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Mar 30, 2009 | Microsoft Windows XP Professional
Svchost exe application location error instruction at 0x00d896bc
This error is generally caused due to conflict between windows updates and svchost.exe. For resolving this problem you have to download a hotfix from microsoft.com. There are some workaround as well to resolve this issue:
Method 1 loadTOCNode(2, 'workaround'); Leave the svchost.exe - Application Error dialog box open, and then follow these steps. Step1: Check whether settings for the Automatic Updates service and for the Background Intelligent Transfer Service (BITS) are correct loadTOCNode(3, 'workaround'); To do this, follow these steps:
  1. Click Start, point to Run, type services.msc, and then click OK.
  2. In the details pane, locate and double-click Automatic Updates.
  3. Click the Log On tab.
  4. Make sure that the Local System account option is selected and that the Allow service to interact with desktop check box is cleared.
  5. Make sure that this service has been enabled in the Hardware Profile list. If this service has not been enabled, click Enable to enable the service.
  6. Click the General tab, and make sure that the Automatic option is selected in the Startup Type list. Under Service status, click Start to start the service if it is not already running.
  7. Repeat steps 2 through 6 for Background Intelligent Transfer Service (BITS).
Step 2: Reregister Windows Update components loadTOCNode(3, 'workaround'); To do this, follow these steps:
  1. Click Start, click Run, type REGSVR32 WUAPI.DLL, and then press ENTER.
  2. When you receive the "DllRegisterServer in WUAPI.DLL succeeded" message, click OK.
  3. Type the following commands in the Open box, one after the other, and then press ENTER after each command:
    REGSVR32 ATL.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Step 3: Rename the Windows Update temporary folder loadTOCNode(3, 'workaround'); The temporary folder of Windows Update may be corrupted. In this case, you can rename the temporary folder of Windows Update. To do this, follow these steps:
  1. Click Start, click Run, type cmd, and then press ENTER.
  2. At the command prompt, type net stop Wuauserv, and then press ENTER.
  3. Click Start, click Run, type %windir%, and then press ENTER.
  4. In the folder that opens, locate and rename the SoftwareDistribution folder to SDold.
  5. At the command prompt, type net start Wuauserv, and then press ENTER to start the Automatic Updates service.
uparrow.gifBack to the top Method 2 loadTOCNode(2, 'workaround'); Follow these steps:
  1. Click Start, right-click My Computer, and then click Properties.
  2. In the System Properties dialog box, click the Automatic Updates tab.
  3. Click Turn off Automatic Updates, and then click OK.
  4. Restart the computer.
  5. Use the Windows Update Web site to install updates manually.
  6. After you install the updates manually, turn on Automatic Updates.
Link for downloading Hotfix :
http://support.microsoft.com/kb/927891/
Download the one which is for your Operating system.
Dec 26, 2008 | Computers & Internet
HP Media Center PC M260n (DF200A#ABA) PC Desktop Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
