Home | GE | Profile PDW8400J Built-in Dishwasher | Blocked drain mes...
GE Profile PDW8400J Built-in Dishwasher
Problem for GE Profile PDW8400J Built-in Dishwasher
Blocked drain message on GE GSD2800 dishwasher
By jamesclose on Jun 27, 2009
On the "rinse only" cycle, I get a "blocked drain" message on the display about 7 minutes into the 12 minute cycle. The diswasher continues to try to pump, but eventually the blocked drain message begins to flash. When I cancel the rinse cycle to abort, the dishwasher continues to try and complete the "drain" function, but doesn't, so I have to turn off the diswasher at the breaker box. I poured a whole bottle of drain cleaner in to try see if there was a blockage, but that didn't work, and my gut feeling tells me that is not the problem, because I would be getting blocked drain elsewhere if that were the case, I believe. Any ideas, anyone?
Comments:
Jun 30, 2009
- This solution did not address the problem of the blocked drain message. I was skeptical that it would, because the plastic screen-looking thing that Gary1121 refers to does not sit at the bottom of the tub, so therefore it can't be a drain (which has to be at the lowest point of a vessel in order to perform that function. Nevertheless, I took the screen off, which is apparently a filter of some sort, and cleaned it off, and replaced it. It did nothing to fix this problem. Again, the dishwasher, after going through the pre-rinse cycle (about five minutes), is apparently unable to drain the water and displays a "blocked drain" message. The owner's manual for the dishwasher gives these possible causes:
1. Clean the air gap [I don't have an "air gap" per se - the dishwasher drains into a common drain pipe that also serves the kitchen sink, so since this is open to the air (although there is a U-trap), it effectively serves as an air gap, I believe, so cleaning isn't an issue, and there is no indication that the common drain pipe is clogged in any way]
2. Check for a kink in the drain hose. [none]
3. Check plumbing for slow or stopped drains [no indication of this problem here or anywhere else in the plumbing].
So what could this be? Any other ideas before calling a technician?
Jul 01, 2009
- You asked, "why would you think that if the drain was blocked in the dish washer that you would have problems else where in the plumbing???" Because it's a logical inference to make: if the dishwasher drain is clogged, one possible reason is because there's a clog further down. It's one of several possible explanations. As for the drain cleaner, I don't think it did any damage. My intention was for it to work its way through any clog in the dishwasher drain line, but it doesn't seem to have helped. My other thought here is that if there is a drain solenoid, it is not operating properly, and perhaps needs to be replaced. That could also cause the "blocked drain" message, I think. Any thoughts on that?
Solution #1
posted on Jun 27, 2009
Not Helpful)
gary1121
Rank: Wiz
Rating: 85%, 110 votes
pull the bottom tray out, in the back portion of the center of the dish washer there is a plastic screen looking thing, you will need to take a 1/4 inch nut driver and take out the screw pull off the cover and clean out the drain,, there is probly some food particals in there , it does havea small blade inside there to help sut up fine food that gets thru but it doesn't do it all the time ,, make sure you put the cover back on before runnig the unit
Comments:
Jun 30, 2009
- why would you think that if the drain was blocked in the dish washer that you would have problems else where in the plumbing??? I have done plumbing and worked n several dish washers and from what you wrote on the original message this is how I came the conclusion,, and YES the dish washer drain can be blocked without haveing any other plumbing problems,, it has it's own pump and only a 1inch drain line that comes off of it,, now that you have more information on the board you need to replace the pump that drains the unit, it would be the big motor looking thing under the center of the dishwasher, it has the hose comming out of it,, YOU DON'T NEED TO HAVE PROBLEMS ANY WERE ELSE IN THE HOUSE DRAINAGE SYSTEM TO HAVE A DISHWASHER CLOGGED, AND NOW THAT YOU PUT DRAIN CLEANER IN THE DISHWASHER YOU ACTUALLY NEED TO REPLACE THE WHOLE DISHWASHER,, YOU HAVE JUST TURNED THE HOLE DISHWASHER TOXIC, AND NOT FIT TO BE USED BY ANYONE EVER AGAIN
Was this helpful?
Yes
No
Solution #2
posted on Jul 07, 2009
Not Rated)
realsync2003
Rank: Master
Rating: 86%, 13 votes
try this, pull d.w. out and disconnect drain but lift it up and put in sink from out side then try to run and see if it drains this will tell you if pump or other mechanical issue is the cause. not all dishwashers are installed in common way.
Was this helpful?
Yes
No
Popular Solutions for GE Profile PDW8400J Built-in
Questions and Unsolved Problems for GE Profile PDW8400J Built-in
Do you recommend GE Profile PDW8400J Built-in Dishwasher?
Answer
Answer
won't wash dishes, acts like it has no water supply, electicity connected
Answer
I have a GE Profile Quiet Power II, the latch has jammed and will only go 1/2 way. I can't close to... (More)
Answer
It doesn't seem to be cycling correctly. Stuck on drying but not draining
Answer
Where may I obtain an owner's manual with instructions on how to use the GE Profile dishwasher?
Answer
my ge profile dishwasrer will not unlatch to open the top latch seems to lift up, but not unsecure... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile PDW8400J Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
