Question about Apple iPod classic 6th Generation Digital Media Player
What is wrong when you get the message connect to power
  • 341 Answers
It means you need to connect it to your computer, using the USB cord that came with it.
Posted on Aug 27, 2009
Canon MP700 Multifunction printer displays message "Wrong cartridge"
1. With the printer powered off but connected to a power source, press the Power button while
pressing and holding the Stop/ Reset button.
2. When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4. When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in. (orange and green, starting with orange.)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 24, 2012 | Canon MultiPASS MP700 All-In-One InkJet...
Have acer one message says to plug into ac adapter
Check the AC adapter and power cord. It sounds as if either one end of the cord near the transformer box is loose, or the end that plugs into the computer is loose/not connecting properly.
Failing that, make sure the wall socket you have the cord plugged into has power (try plugging something else into it). If everything I mentioned checks out, there could be something wrong with your battery.
Mar 23, 2012 | Acer Aspire One D255 Netbook
I am getting a "wrong print head" error message.
Turn the printer off.
Disconnect the power-cord from the wall-outlet.
Reconnect the power.
Turn the printer on.
If you still get the same message, it's time to responsibly recycle the printer,
and buy a replacement -- maybe you can buy a new PIXMA that takes the same ink-cartridges???
Dec 08, 2010 | Canon PIXMA MP810 All-In-One InkJet...
I have a samsung 17'' lcd monitor.when i power on my monitor without data cable i got a message on screen CHECK SIGNAL CABLE.when i connect data cable my lcd is going to power off.please help?
The message says that the monitor doesn't receives signal - which is normal. Since the problem appears only after you plug in the cable in means that the problem is located there - something is wrong with your pc, most likely the video card has died.
Oct 03, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Sony VGN-TX750P laptop Operating System not found message
try seating the hard drive, the HDD might have been loosened when you changed the part.
Hope it helps!
Feb 14, 2010 | Sony VAIO VGN-A170P Notebook
Laptop only works with mains power supply connected
When you power your system up do you get a message saying battery charge failure or some other disappointing driver message? Try powering down, removing the battery, and look for a little button on the underneath of the battery. You should be able to press this button and a series of lights will or won't appear. If they light up it means the battery is truly charged. If not there is something wrong with the connection. Try wiping the surface off and replacing the battery. Also make sure the pin that you place into the laptop to charge the battery is free of dust, etc.
Aug 30, 2008 | Compaq Armada M700 Notebook
Kenwood Midi M-97/M Switch power on and after a few seconds i get a protect message appear on A-97 amplifier and it blocks use of the system. -Paul
this is prob because of a wrong connection between speakers connections + to + - to - check all speaker wires are correct with no shorting out between + & -
Steve
May 15, 2008 | Audio Players & Recorders
Can't get it out of Demo mode
hi sir,
if all the buttons dont work when pressing it, maybe there is a lost connection of the buttons or buttons are shorted. try to check it out...
hope it can help...
Oct 13, 2007 | Sony STR-DE845 Receiver
Apple iPod classic 6th Generation Digital Media Player Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
