Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
Hoover dual V. DETERGENT DISPENSER WILL NOT DISPENSE.
One thing I thought of--the clean water tank has a small (about 2mm) plastic rod that pushes the valve open. There is nothing like this on the detergent dispenser side. Thanks
2 Suggested Answers
  • 11 Answers
SOURCE: Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Tom
Posted on Oct 22, 2009
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
would suspect.
Tom
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Solution does not dispense
The trigger that releases the water is connected by a piece of plastic inside the handle. This plastic tends to bend over time, so it won't press the plunger high enough. I brought it to a vac repair place for the same reason and they added an extension which made all the difference. If I were to do it myself next time, I would look to see if a metal rod were possible to take the place of the plastic. Maybe not, but it would be worth a look.
Nov 05, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate won't dispense clean solution
The tank sits on what is called a reservior asm, that may have gone bad. Does the water flow out of the tank when you push in the valve at the bottom?
May 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Clean water tank
Will the water come out of the tank when you depress the valve at the bottom og the tank? The tank sits on a resevroir asm., is the seal on it, black and round. Inside the handle is a rod, so when you squeeze the trigger, it pushes onto the reservoir to release the water, check to be sure it is, if not then you have a problem inside the handle or a bad reservoir asm. is bad.
Feb 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Detergent won't dispense
Check the valve at the bottom of the tank, does it push up then come back by itself (part #43513014)? If it is ok, then there may be a problem with the plate that the tank sits on or the plunger inside the handle isn't pushing to release the detergent.
Feb 08, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover FloorMATE 3000 won't dispense cleaning solution.
I had the same problem with my Hoover Floormate H3000 and found the solution elsewhere on this website. Try doing a search for Hoover Floormate H3000. The posted solution is basically as follows:
Remove the liquid dispenser tank and set it aside. Look into the cavity of the machine where the tank attaches and find the plastic "plunger" piece (the one on my machine is a blue/grey color) that is surrounded by a black rubber circle. Put a small drop of hot glue on the tip of this plastic "plunger" piece and let it harden. Replace the liquid dispenser tank and try the machine again. My machine dispensed liquid properly after this fix-it.
I really appreciate the poster who provided this simple solution!
Nov 19, 2006 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
140 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
