Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Anti-afterfire solenoid This part seems to be the problem for my mower not starting. It just clicks. Craftsman 917274821, 18.5 hp. Where can I get this replacement part?
  • 376 Answers
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
Posted on May 15, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
bargainbin2
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
RonInFla
  • 86 Answers
SOURCE: STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Posted on Apr 18, 2010
Testimonial: "Haven't tried the suggested solution but makes sense."
What is the electrical part on bottom of carburetor and what does it do
Some lawn more motors include a anti dieseling l solenoid to restrict fuel from entering the carburetor after engine shut down. The technical name is "anti-afterfire solenoid"
When the key is turned on the solenoid retracts allowing the gas to enter the engine as the engine is cranked. When the engine is turned off and no spark condition the engine can continue to run igniting the fuel from a glowing combustion chamber (like a glow plug engine). This device prohibits fuel from continuing to enter the Carburetor after the key is turned off, No spark, no fuel engine will stop.
Nov 25, 2015 | Garden
I have a white mower with a 18 hp intek v-twin briggs & stratton motor. I was cutting the lawn and it loss power all of the sudden, then it died. Now it won't start. I changed the plugs, which looked...
back pressure is from a blocked muffler ( carbon build up)
if it is that old then it could be overheating from grass and dirt build up around the cylinder fins and not cooling properly
Apr 06, 2017 | Briggs & Stratton Briggs Stratton Intek V...
I have a craftsman 18.5 hp twin model 944.607390 that will not start. when you turn the key it just clicks.
check connections at battery and the battery if good check the fuse by solenoid if good need to test the solenoid itself
May 18, 2010 | Craftsman Garden
Craftsman Lawn Tractor, 18 HP, 44" Cut; No SWtart!
Check the by pass switches on the seat, clutch pedal, and check the fuses.
May 15, 2010 | Craftsman Garden
I have craftsman tractor Model 917.272751. Now engine clicks but will not start. I checked Starter. It is good. What is the posible probelm? Thanks
If it just clicks and won't crank, most likely it is your starter solenoid.
You can verify this by "jumping" across the 2 large posts on the solenoid.
If it cranks doing that then the solenoid needs to be replaced
Oct 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman zero turn model# 107.27774
If you are jumping the solenoid and it cranks but wont start leave the key in the on position and give it a try. Try replacing the solenoid and the wires conecting it to the battery.
Apr 24, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,700 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
