Question about Kitchen Ranges
My stove is giving me the error message F2E0, stuck key
  • Kitchen Ranges Master
  • 8,220 Answers
Get a heat gun or hair dryer or extremely hot wet rag and warm the buttons . kill the power and retry
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 27, 2009
  • eunicelibycz Aug 07, 2011
    Worked like a charm. Let's see if it will last. I'll cross my fingers.
My whirlpool electric stove keeps beeping it shows f2E0 why is it doing that?
The F2 E0 error means that the control board believes that a key on the touch pad has been held down for an extended period or has shorted. Assuming that no one is holding the buttons, try pressing Cancel to clear the error. If the error recurs promptly, check the wiring harness between the key pad and the control board to make sure that the wires are tightly connected. If the problem continues, you probably need to replace the touch pad (key pad) assembly. On some Whirlpool models, the keypad and the central control board are sold as a single assembly. In that case, you'll need to replace the entire unit.
If you add a comment with the model number of your stove, I may be able to give you the part number for the keypad. I hope this helps.
Jul 17, 2015 | Whirlpool Kitchen Ranges
Kitchenaid Ykers807ss00 error display f2e0
this is the procedure for this code,
F2
Keypad
E0
E1
STUCK KEY (shorted key)
KEYPAD DISCONNECT or KEYPAD DISCONNECTED
PROCEDURE: Before proceeding, perform steps 1 through 3 above chart to enter the
Diagnostics mode.
A. Unplug range or disconnect power.
B. Check that the keypad is firmly connected.
C. Plug in range or reconnect power.
D. Observe for longer than 1 minute.
E. If error remains then go to step F.
F. Unplug range or disconnect power.
G. Replace keypad.
H. Plug in range or reconnect power.
I. Observe for longer than 1 minute.
J. If error remains then go to step K.
K. Unplug range or disconnect power.
L. Replace display board.
M. Plug in range or reconnect power.
Here is the board to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 10, 2013 | Kitchen Ranges
I am getting an error code f2eo and it is saying stuck key. No button will work.
Error code f2e0 means the touchpad is bad. Give me the part number, or go to ApplianceTimers.com, we may be able to repair it.
Mar 20, 2011 | Kitchen Ranges
Whirlpool Accubake F2EO
F2E0 is shorted key pad. You will need to replace keypad if the power shut down and reset does not work.
Mar 09, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Kitchenaid electric range yker1201 with f2e0 error
F2-EO indicatwes a shorted key pad. Electronic parts on ranges sometimes have warranty for five years (may only cover parts) so check your owners manual to see what your warranty is then call for service. It is a good idea to save reciepts of repair for future reference if neccessary.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
F2e0 error on stove
"cycle the circuit breakers" is to turn the switch for the stove at the electric switch box at the main feed of the house electric panel. This is equivalent to unplugging the stove and plugging it back in.
In the old days, a circuit breaker was a "fuse" in the "fuse box"...
Kitchen Aid KESA907 Error F2E0 Stuck Key
Turn off the breaker and wait for 5 minutes. the follow these steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Apr 24, 2008 | Whirlpool GERC4110PS Kitchen Range
Kitchenaid glass top electric range
I have the same problem...stuck key err F2E0
Can any one please tell me where is the sensor? I mean which part of the oven have sensor, is it inside or under the button control panel?
May 27, 2007 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
1,407 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
