I CLEANED THE WATER CONTAINER. AFTER THAT IT WONT WORK. I FOUND A SMALL METAL CLIP IN SINK, NOT SURE IF IT GOES TO THIS MACHINE AND THAT'S WHAT MAKING THE RED LIGHT FLASH RAPIDLY.
I guess it's the metal part in the water tank that makes contact with the machine when the water runs out. When you take the water tank off the Senseo it's in the bottom right corner. If you can't repair it, a spare water tank isn't that expensive.
SOURCE: Senseo 7814 does not heat water and red light keeps flashing
is the red light flashing as though not enough water, if so use a magnet to connect to the valve inside the machine, the valve can be found along the water level where the float is. what is happening is that the float is stuck. by connecting the magnet to the valve and very slowly moving the magnet along the water level, upwards the valve will follow and the water will begin to heat as the light changes to a slow flash, if it doesn't work try again as you have not connected to the magnet
