Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Recode a Linear LDO33 remote
One of my remotes was stolen and I want to change the code so they cant open my garage door. I came home today and it was open. I still have one other remote. Please help!
    President:
  • 3,197 Answers
Go to this site which is a pdf file and follow the instructions "To remove all controls." That will do what you want.
http://www.linearcorp.com/pdf/manuals/LDO_user.pdf
Posted on Jun 27, 2009
My linear garage door opener will work now and than ? on remotes but works fine with hard wired remotes ?
how old are the batteries in the remotes. Hard wired remotes usually don't have a wire length limit.
Oct 01, 2014 | Linear Corporation Linear Garage Door...
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Help truck was stolen, I used remote control to "teach" truck how to open door... I reset door opener and relearned the remote..my question is do the remote have a new entry code when I learn, or remote is...
Ounce you reset ALL code of the garage door opener (engine hook up to the ceiling of the garage that open up the door), ounce you press the reset button on the unit, it disable all transmitter (portable or the one install in your vehicle). Your garage door opener has a receiver in it and your all units that you press on to open the door are the transmitter, so by pressing the reset button on the door opener, you erase all codes of all the transmitter that where programmed to open-up that door.
So if you teach your vehicle using a portable unit and you now reprogram your new vehicle with the SAME portable transmitter, then yes who ever has your stolen vehicle can come back with your stolen vehicle to your house and open up your garage door since you re-programmed the door opener using the SAME transmitter same code sent to the unite to active it).
Buy a new transmitter to re-programmed your new vehicle
Jul 13, 2014 | Building Materials
I purchased a model 139.53915D garage door opener a couple of months ago. My problem is I have come home twice to find the door wide open for no reason. Today I came home and it was open half way. This is...
Take your remote and your garage door opener and change the codes on them. You will have to take the cover off of the garage door opener to do this also. You will see where you can choose a different code. Just make sure you have the same code set on the opener as you do on the
remote(s). There someone near you who is on the same frequency probably or there are also other radio waves that can do this that are not from garage door remotes. Changing the code should do the trick.
Mar 29, 2011 | Garden
I have a Craftsman keyless gargage door opener model 031D0431. We just moved in and would like directions on how to recode the keyless entry. One more question...if I recode the keyless entry, do I have...
Coding the keypad will not affect the remotes if you follow these directions.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in a four digit code and press enter.
Oct 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I change the code for the door opener and remote. I have a craftsman 1/2 HP garage door opener. I have door door openers and one remote with three buttons.
You cannot change the code of your remote or opener. It is set at the factory. If you have lost or have had a remote stolen and need to eliminate its possible use you can erase the memory of your opener by pressing and holding the smart/learn button for 6 seconds. That button is on the back of the motor unit near where all those white wires go. Now you need to program your remote by holding the large button down while you press and immediately release the smart/learn button.
Mar 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have a genie garage with two doors and need to change one to open, one of the doors that use to open another door. Other door is opened by bluetooth by autmobile. How do you change code on unit on ceiling...
Go to this site and follow the directions under "Replacing a lost or stolen remote" Then you will need to program your bluetooth.
http://www.aaaremotes.com/gegadooptr1.html
Feb 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote won't work since I changed the code on the garage door opener
thats because you didn't recode the remote to the garage door or you have not recoded it correctly. double check the remotes settings (if it can be changed) to ensure it matches the door opener. Now, if you cannot see any method of changing the remote to suit the main unit, it may be that the remote is factory coded or that it is coded by Soldering links on the circuit board. Carefully disassemble the remote to have a look if it does not have a small bank of switches in the battery compartment. If the switches are there, check the coding is the same as the main unit, if the switches are not there, disassemble and check for solder links on the circuit board. If you are not confident with using a soldering iron, take the remote to someone who is.
Jan 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener
unplug the power of your door opener for a few minutes and plug it back in. Try the remote control that you have and see if it opens the door. If it doesn't open the door, reprogram [learn] the remote control you have and that is it. The other remote will be useless ... and you just proved it to yourself!
Sep 13, 2008 | Kitchen Appliances - Others
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
836 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
