How to make the heater work on the air con in the house split system no user guide its cold
    Sergeant:
  • 340 Answers
Set the thermostat on a higher setting turn it to heat position if that don't work thermostat may be bad. Good luck Tom
Posted on Jun 27, 2009
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
I have two Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner units -- 2 years old. One works fine, but the other does not blow heated air (Heat Mode). It is cold outside, but the good unit is...
your unit may be have possible leak on piping then refrigerant exit or had leakage of refigerant try to locate leak then braze it then recharge a correct amoun of refrigeran. if you use heater try to check heating element if ok by supplying voltage or used ommeter to test continuity.
Feb 03, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
Good after noon i have a Starway Split Wall Mount Reverse Cycle Air Con. the problem i have is when i need to warm my house the air coming from the system is cold. even with the temp setting on the sun...
Examine the condenser. The condenser pushes the air and expels the warm air from the air condition to the house. Also check the fan heater on your system to see if it is functioning, because if it is not, it will circulate the heat from the unit to the house, in this case,it will need to be fixed. also check if the thermostat on the unit is regulating because if it is not regulating, you will not get the house to warm due to bad thermostat, check to ensure it is regulating, if not, replace it, it might be defected because that is the key to regulate the unit. so pay attention to it to see if it regulating the unit, if not, replace as advice.
Take care.
Jun 12, 2010 | Heating & Cooling
My heater doesn't work!
Check operation of the heater core coolant control valve and associated remote control mechanism.
Chech heater coolant hoses are not kinked or crushed,
Check that both inlet and return heater hose is equally warm, as this indicates coolant flow through the heater core.
If no coolant flow:-
Check cooling system is correctly filled, taking care to bleed off any air locks from the system as necessary (with heater coolant valve open);
Check heater core is not blocked- if blocked you may be able to backflush.
Try this link for a free manual:-
http://safemanuals.com/user-guide-instructions-owner-manual/OLDSMOBILE/ACHIEVA%201998-_E
Oct 19, 2009 | 1998 Oldsmobile Achieva
LG S36AHP-UD7 Split Air Con. won't turn on.
Generally when an ac trips the main breaker and the breaker its self isn't bad, the compressor is going bad or is bad. To check you will need to do an ohms test on the compressor. If you get a reading of less than infinite, then the compressor is bad. You will need to test every lead going to the compressor which is usually 3 unless you have a crank house heater installed but they are not typical on a small unit. If the compressor has gone bad it is possible the it took the board out as well.
Mar 31, 2009 | LG Heating & Cooling
Installing a sump heater or cold weather use.
air conditioner can work at 0 deg C outside temp and you do not need a heater for compressor if is split system.
Feb 17, 2009 | LG LB1200ER Air Conditioner
No heat
Please make sure that the correct mode setting has been selected. Depending on model you will see the mode button has four little icons. A star/crystal, a teardrop, a sun (circle with lines out going) and a sort of triangle. You press this button until the correct icon appears on the display, it should be the sun icon.
Aug 07, 2008 | LG LSC121PMA Split System Air Conditioner
Hitachi RAS-63CHA2 split system reverse cycle air con
You can try universalremote.com but it cost me 15USD for digital delivery. Its better than being cold and I have spent hours on the net to no avail.
May 22, 2008 | Hitachi RAS-09UH Air Conditioner
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
