Question about NEC MultiSync MT1050 Multimedia Projector
Nec mt/1040 Hello, I just found you all. I am having a problem w\ nec mt10/40 projector. lamp lights do not hear a fan. the lamp goes out. I downloaded a copy of the service manual w\ schematics but would like any insights that you have regarding if it is not the fan itself. niether the intake or exhaust fan seem to come on. Could it be in the power supply for the fans.I can be reaCHED AT RODNEY.R.BROWN@THOMSON .COMThanks forr your help Rod
  • Chmed May 11, 2010
    Where online would you download this service manual?
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
Doug.
Posted on Dec 10, 2007
If you have the schematics look on the power supply board circuit. It looks like there is a linear regulator that feeds the fans. My guess is that the regulator is bad or there are broken solder joints in that circuit.
Dave
Posted on Nov 29, 2007
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
The status light is on our NEC MT850 and the bulb looks fine. What other problems could it be?
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 19, 2012 | NEC MT850, MT1050, MT1055, MT1056...
I just bought a used NEC Multisync MT 840 projector with just over 600 hours on the lamp counter. I live in Japan. After about 4 or five minutes of working, the projector turns itself off and won't...
hi,
Possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. if the RPM of fan is low then the lamp can get over heated. May be its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
i have added a video how to oil the fan for make it easy for you.
ok
May 08, 2011 | NEC MultiSync MT840 Multimedia Projector
Nec mt-1065 lamp hours reset
Hello, unfortunately the NEC MT1060 - MT1070 series projectors have EEPROM chips built into the lamp housing which counts the hours that the lamp has been used for so the only way to reset the hours is to change the lamp for a new one, i have not yet found a way to reset the chips even by reprogramming them, i'm afraid the only solution is to replace the lamp with an official NEC unit, but this was obviously their intention.
Oct 25, 2010 | NEC MultiSync MT1065 Multimedia Projector
MT 1050 Lights, goes out then Status light error
I have the same issue with mine. Did you ever find a solution? Thanks!
Sep 17, 2009 | NEC MultiSync MT1050 Multimedia Projector
Lamp and user's manual for a NEC Multisynch MT Projector
The manual can be downloaded here: http://safemanuals.com/user-guide-instructions-owner-manual/NEC/MT600
The part number for the replacement lamp is MTLAMP600/800 and it may be ordered from www.partstore.com
Mar 02, 2009 | NEC (SPPL1063) Projector Lamp for MT600,...
Resetting Lamp Hours Procedure On Nec-MT-1075
Hi - You can download the manual by clicking the link underlined in blue below:
Nec-MT-1075
See page E-55:
As in the note replacing the lamp automatically clears the lamp hours.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 05, 2008 | NEC MT1075 Multimedia Projector
Preylahong NEC MT830+need help to reset new lamp
After replacing lamp in MT-830(NEC) press and hold "on" button for 10 seconds to reset lamp hours. If projector has beyond 2100 hours press the "off" button for 10 second.
May 01, 2008 | Office Equipment & Supplies
Changing the lamp
There is a small cover plate, about 3"X6", that 'just' snaps off. You might have to use a small screw driver to pry it open. The bulb can then be pulled out. Align the new bulb and press it down into the socket. Be careful not to touch the bulb with your hands; use gloves or a lint free cloth.
Aug 13, 2007 | NEC MT1075 Multimedia Projector
NEC MultiSync MT1050 Multimedia Projector Logo
421 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
