Question about HP Office Equipment & Supplies
How to scan a document where it doesn't take so much space? When I scan a contract of 8 pages it is like 13MB. I need it to be smaller like in KB.
  • ashlynstremp Jun 27, 2009
    I am scanning as a PDF. I just did 2 pages and it was 4MB. That is on gray scale.
    President:
  • 1,901 Answers
One of the main ways to reduce document size is to consider what format you are saving them as.
I just did a sample scan and the following are the results of different formats:
.png - 88 KB
.gif - 108 KB
.bmp - 192 KB
.tif - 196 KB
.jpg - 1.14 MB
As you can see the JPG file is over 10 times larger than the PNG file.
Also make sure that you do not scan as a color scan if it is not needed. The above scans were all scanned in black & white.
I hope this has helped you. Thanks for using Fixya.
Wayne
Posted on Jun 27, 2009
  • Wayne Mineard
    Wayne Mineard Jun 27, 2009
    Another setting that will make a difference is the resolution. Try scanning at 200 or 300 DPI max.
VuPoint Magic Wand scanner. I'm very happy with the quality of the scans, but the problem is that the PDF and JPEG files that it creates, even on low, mono resolution, are huge.
Look for the firmware update for your specific model and download and install make sure you choose the right model. You can mess up your scanner completley if you choose the wrong one. Software Driver Downloads User Manuals Warranty Card
Mar 20, 2014 | Office Equipment & Supplies
Can I scan multiple pages to a PDF?
1. Open the HP Solution Center 2. Click Scan Document 3. Document to PDF File 4. Change Settings 5. Save to File Save Options 6. Make sure One file per scanned page is not checked. 7. Click, OK > Scan 8. Ofter first page is scanned, position next page on scanner, then click Add Page. 9. Keep doing step 8 until all pages scanned. 10. Click Finish.
Apr 01, 2010 | HP Photosmart Premium C309A All-In-One...
When i scan a document the file size is too large. a 1 page document scans as over 27,000 KB using 300 dpi. if i use smaller dpi the print is too light.
1. Increase the contrast on the print. That is increase the ink that is dispensed.
2. Check the user manual as to how to do this function.
3. It seems at this resolution the printer reserves the ink dispensed when this size print is selected.
Feb 03, 2010 | Lexmark X8350 All-In-One InkJet Printer
Dr-2050c multi-page document stops scanning after one or a few pages, inconsistently. Feed lever is down in the multi-page position. Feeder tries to separate the pages: sometimes it succeeds. Document...
If the scanner is scanning but stops after a few pages either it could be because of a) There is insufficient disk space (you need to delete unwanted files or direct the comp to store whre there is space) or b) the rubber rollers are not able to separate pages and feed the papers for scanning.(You need to change the rollers)
Jun 08, 2009 | Canon DR-2050C Path-Through Scanner
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Scanning several pages and saving as one document
Try this....
Scan your multiple pages to an image file, like .jpg, I know it's tedious, name them (optional) by page number, put them into an empty folder.
When you're done with all the scanning, open the folder, select all of them, open with: Preview.
Now, you should see one page, with a side bar containing all of the pages. (If they're not in order, you can drag and drop within the sidebar to reorder.) Select all of those (Or Command A)
Command P (Or Print)
In this window, you should see page one, and below that, make sure it says "Page 1 of XX"...this way you know you got 'em all, and it's your final opportunity to page through them all by clicking on the little arrows to make sure they're in the right order.
Click the PDF button
Save as PDF...
See if that helps
Jan 15, 2009 | Brother MFC 420CN All-In-One InkJet...
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
S. Mohan, Chennai, India
Nov 26, 2008 | Canon DR-2580C Path-Through Scanner
Single scan printers can be difficult in this manner.\
Consider using the OCR (optical character recognition) software that came with your scanner.
Basically the part of the software that asks you what you are scanning (picture, document, newspaper) and make sure to select document. This will enable the character recognition which will convert the scanned picture into a document that you can configure to go into Microsoft Word or Notepad or whatever. If you have multiple pages, it MIGHT give you the option to scan more than one page at a sitting. then again, it may not. In which case you might be kicking yourself for not purchasing the scanner with the auto feed attachment! Once you have made your scanned document in your word processor - READ THROUGH IT! may have converted characters incorrectly - like an "S" may be now a "$" it happens - and it will happen. When done, attach complete document to email and BOOM done.
Either this or use a fax machine :)
hope i helped!
Ryan
May 31, 2008 | HP PhotoSmart C4280 Laser Printer
Scanner Creates a Very LARGE PDF file 1.8 meg for one page
I have an old X7170 and have the same problem when using the doc feeder. I scan using the flatbed the size is much much smaller.
May 05, 2008 | Lexmark X83 All-In-One InkJet Printer
116 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
