Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Runs just fine,after awhile it acts like it runs out of gas. after it cools have to crank it for a while then starts and runs. Fuel filter or pump
  • 3 Answers
Coil could be over heating or spark plug might be breaking down when hot, or check vent in fuel tank cap.
Posted on Dec 15, 2009
1998 Nissan Altima GXE 2.4L Automatic
Make sure you get a fuel pressure reading to know if you need to replace the fuel pump assembly...it should have 43 psi reading. If it is bad the fuel filters need replaced too. A fuel pump should never be ran lower that a quater of a tank because it kills the life of the pump, it acts as the pumps cooling system. Check for spark and see if there are any engine codes like a bad crank signal. Good luck
Feb 21, 2016 | Nissan Cars & Trucks
Fixya manuals
It sounds like the fuel filter may be blocked and restricting free flow of fuel. The pump may be supplying enough gas to fill the lines at a slower pace than the engine uses it up because the filter is clogged. Try changing the filter first. If you are able to check the fuel flow when cranking the engine while not creating any sparks, that would be the safest way to check for fuel flow.
Aug 24, 2014 | Ignition System for Honda Accord Sedan
1978 chevy wont run except with starting fluid
yes they do go bad take the air cleaner off crank it and see if your getting in the carb
Sep 27, 2012 | Cars & Trucks
Truck will crank and run fine till it warms up...when im on the interstate running a steady speed it acts like its running out of fuel or lossing spark... if i let off the gas it will clear up then start...
Have you had the computer scanned? It sounds like a fuel injector problem. Injectors may be dirty. Or possibly a fault in the injector circuit. You didn't mention changing the fuel filter. I know some of the Dodges have the filter integrated with the pump. If yours has an independent filter it should be replaced.
Jan 05, 2011 | Dodge Ram 1500 Cars & Trucks
Truck acts like it is running out of gas? Replaced fuel filter. Ran fine for awhile but now still acts like it is starving for fuel.
my '93 f-250 (4.9L) stopped running while driving, now it acts like it isn't getting any fuel. Tried switching tanks, but still does the same. What would be the problem.
Aug 17, 2010 | 1993 Ford F250
Takes several cranks to start truck,even though it is fuel injected.once started,fuel is pumped fine.
May be having fuel pressure problems. I would change the fuel filter if you haven't in awhile. A plugged filter will cause the fuelpump to overwork, not build proper pressure & wear out prematurely.
Jun 14, 2010 | 1997 GMC Sierra
Aftter driving for a few minutes vehicle dies, after waiting awhile it will start back up. Acts like gas but changed fuel filter, almost as if it cools a bit about 15 miutes and starts up.
Sounds like a bad fuel pump. Check fuel pressure.
Also could be the fuel pressure regulator that supplies fuel pressure on start up before your fuel pump has a chance to build up fuel pressure.
Feb 28, 2010 | 1990 Buick Skylark
Doesn't always start , has problems in the morning, after it sits for awhile. somestimes it starts alright sometimes it doesn't,acts like it may be out of gas, cranks over and acts like it wants to start,...
May have a fuel pump going bad or a fuel filter clogged. When the fuel pumps go bad they tend to not hold fuel in the line and it leaks back to the tank. That could be causing your hard start sometimes and not others.
Oct 10, 2009 | 1997 Pontiac Sunfire
1993 Honda Accord LX Wagon won't start
Have you changed the crankshaft position sensor
Sep 20, 2008 | 1993 Honda Accord
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
661 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
