Question about Gateway (5500652) (  5500652) DVD Drive
Does not play under device manager says code 39?
    President:
  • 1,257 Answers
Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
Posted on Jun 27, 2009
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
DVD/CD drive won't recognize discs. System says corect driver installed
Is it a disc that someone made on their computer and gave to you or is it one you purchased from the store? Computers sometimes have a hard time reading a disc that someone made and gave to you. Try a disc that you purchased and see if it plays it.
See if you can update the driver in the device manager.
Uninstall the DvD Drive from the device manager, then reboot and let it reconfigure everything. Go the Control Panel and under System find the device manager. Right Click on the dvd drive and select uninstall. Reboot.
Reseat the the disc by unplugging the power cord, remove the battery, then turn the laptop over and remove the screw that holds the dvd drive in place. Pull the drive out, then put it back it.
If you are using Windows Media Player try the VLC player.
Try using VLC as your player. Go to www.google.com andin the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Downloadand install it. It downloads and installs in 3 minutes or so. It'sa very fast player, smooth and it can play just about any type of dvd formatsand media. It's totally FREE.
Apr 14, 2012 | Computers & Internet
Driver for iphone4 code 28
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue. Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Jan 08, 2012 | Microsoft XP Computers & Internet
I cant burn a cd or dvd
You can try this work around.
Here's How:
  1. Click on the Start button.
    If you're using Windows XP, also click on Run.
  2. In the search box (Windows 7 and Windows Vista) or the Run textbox (Windows XP) type regedit and click OK or press the ENTER key.
    This will open the Registry Editor program.
    Important: Changes to the registry are made in these steps. Take care in making only the changes outlined below. While it's not a necessary step to complete this process, I recommend that you play it safe by backing up the registry keys you're modifying.
  3. Locate the HKEY_LOCAL_MACHINE folder under Computer/My Computer and click the '> or (+) icon next to the folder name to expand the folder.
  4. Continue to expand folders until you reach the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class registry key.
  5. Click on the '> or (+) icon next to the Class key to expand it. You should see a long list of subkeys open up under Class that look something like this: {4D36E965-E325-11CE-BFC1-08002BE10318}.
    Note: Each 32-digit subkey is unique and corresponds to a particular type, or class, of hardware in Device Manager.
  6. Determine the Correct Class GUID for the Hardware Device. Using this list, find the correct Class GUID corresponding to the type of hardware that you're seeing the Device Manager error code for.
    Hope this helps.
    Regards,
    Meir
Nov 05, 2011 | Microsoft Windows XP Home Edition
After i tried to burn a dual layer dvd it got burn failed and it stops reading dvd disks
Try this.
Here's How:
    Hope this helps.
    Regards,
    Meir
Oct 11, 2011 | LG GH22LS50 DVD-RAM Burner
No sound when playing music files
Seems like your sound driver is not installed, right click on My Computer and click on Properties, go to Device Manager and see if you have any "Unknown devices" that needs to be installed
Sep 08, 2011 | Computers & Internet
I'm looking for drivers or software for a Norcent LM965WA monitor, can you help?
Look in Device Manager under "Monitors". Does it say "Plug and Play"? If so, you don't need any monitor driver.
If this helped please give 4 thumbs!
Thanks
Aug 25, 2011 | Computers & Internet
Code 28
Code 28 Error Message
The Code 28 error is one of several Device Manager error codes. The Code 28 error will almost always display exactly like this:
"The drivers for this device are not installed. (Code 28)"
Details on Device Manager error codes like Code 28 are available in the Device Status area in the device's properties: How to View a Device's Status in Device Manager.
Aug 23, 2011 | HP Computers & Internet
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Resolution
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
Open Questions:
iTunes can no longer find my CD burner. Using a gatewayM-1631U laptop, with windows 7 x 64 home premium edition. (See additional details below). I use iTunes regularly, and as recently as Xmas 2009 was burning music CDs frequently on my laptop. Yesterday I attempted to burn a CD, and iTunes no longer recognizes the installed CD burner. I have not installed any programs to my computer recently, or made any other changes. Today I began investigating the issue. I have tried (not in order) the following - and have not solved the issue: 1. Going to the registry editor and deleting the lower and upper filters associated with the H_KEY_LOCAL MACHINE/SYSTEM/CURRENT CONTROL SET/CONTROL/CLASS 4DE3695 .... 2. Uninstall and reinstall iTunes (9.0.2.25) 3. Repair iTunes 9.0.2.25 4. Looked for updates for the drivers (can't find any) 5. Downloading Gearsoft products I admit that I have not tried Windows Media Player (because I'm committed to my iTunes - I sync with my ipod all the time and listen to it alot). I also realize I may have made the problem worse by some of my attempted fixes. Here is the information gathered through itunes diagnostics: Microsoft Windows 7 x64 Home Premium Edition (Build 7600) Gateway M-1631U iTunes 9.0.2.25 QuickTime 7.6.5 FairPlay 1.5.23 Apple Application Support 1.1.0 iPod Updater Library 9.0d11 CD Driver 2.2.0.1 CD Driver DLL 2.1.1.1 Apple Mobile Device 2.6.0.32 Apple Mobile Device Driver not found. Bonjour 1.0.6.2 (118.5) iTunes Serial Number 2987488CE609EDAB Current user is not an administrator. The current local date and time is 2010-02-05 07:50:22. iTunes is not running in safe mode. Video Display Information ATI Technologies Inc., ATI Radeon X1200 Series **** External Plug-ins Information **** No external plug-ins installed. iPodService 9.0.2.25 is currently running. iTunesHelper 9.0.2.25 is currently running. Apple Mobile Device service 2.50.39.0 is currently running. **** CD/DVD Drive Tests **** No drivers in LowerFilters. UpperFilters: GEARAspiWDM (2.2.0.1), Failed while scanning for CD / DVD drives, error 2380. Error while opening iTunes CD driver. This could be caused by a corrupted iTunes file or a conflict with other older CD burning applications, either currently installed or previously installed and uninstalled incorrectly. Additionally, the device driver says my DVD/CD unit is: Optiarc DVD RW AD-7563A ATA Device Anything else you need to help me figure this out? Could really use help and advice. Thanks in advance.
Feb 05, 2010 | Gateway (5500652) (  5500652)...
See all Gateway (5500652) (  5500652) DVD Drive Questions
Gateway (5500652) (  5500652) DVD Drive Logo
203 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
