Question about Phil & Teds E3 Jogger
Broken wheel I put too much air in the rear tire causing it to blow up, breaking aprart the plastic and all. I need I whole new wheel. Where do I find one?
  • 508 Answers
Check harbor freight
Posted on Jun 27, 2009
2006 dodge caravan with rear draum brakes. Broken wheel stud on right rear wheel. Got the drum off, got the broken stud off. but i cant get the new stud in. not enough space to get the new stud in. Is...
Make sure all tires are chalked,put vehicle in neutral,turn drum till it has a clear spot to knock stud out,use hammer and wooden block,don't use metal punch,can cause burr on end of stud and not want to come out of hole.Both tires on back may need lifted in air to turn.
Jul 05, 2017 | 2006 Dodge Grand Caravan
Need to replace tire bolts
You should be able to remove the tire and wheel assembly and have the rotor exposed. Remove the two bolts that secure the brake caliber and gently slide the caliper assembly off the rotor. The rotor should then come off. The broken wheel studs can be punched out with a 5 pound hand sledge and a good drift pin. Just install the new wheel studs the same way from the back side.
Oct 22, 2011 | 2004 Ford Explorer
The rear tire is on tight but it wobbles and shakes the whole car when i drive it. it has good tires on it.
3 possible answers. 1 the rim is bent 2 . unbalanced tire 3. wheel bearing needs replacement
Jan 03, 2011 | 2004 Pontiac Grand Prix
I tire on chair that went flat the wheel has a plastic cap for a valve stem how do I put air in the tires?
Rob if you can't find a air stem then you probably don't have air in the tire and it was a foamed filled tire. It doesn't happen often but the foan can break down and cause a "flat". Now look at the other wheel and see if it doesn't have a stem. The parts manual for your chair indicates a solid rubber rear tire so going flat shouldn't happen I would contact the dealer and ask for help with this one sorry I couldn't give you a precise answer. Good Luck
Oct 13, 2010 | Everest & Jennings Advantage Manual...
1994 gmc back left tire break leak
Most likely rellted to the rear wheel cylinder. You need to remove the tire, probably replace the brake shoes if they are wet with fluid, wipe down brake drum with carb or brake cleaner, install new wheel cylinder and put everything else back together. Wheel cylinder is available through most auto parts outlets. Probaby less than $15.
Jul 14, 2010 | 1994 GMC Suburban
What tires do I put the tire chains on for winter driving?
The driving tires ... front or rear wheel drive? 4 wheel drive? put on the rear.
Apr 06, 2010 | 2004 Honda CR-V
Bad virbration
You may have rotated imbalanced wheels from the rear to the front .Its possible not to feel the imbalance from the rear as it is far less sensitive and not transmitting through the steering wheel. Check tire balance or move the tire back to their original position which might help veify the source of your imbalance.
Aug 23, 2009 | 2004 Jeep Wrangler
Vibration
It sounds like a possible bad front wheel bearing they will make like a humming or growling noise.The pull could be air pressure a little lower in the right front tire than the left front check the air in all tires and if pull is still there take the left front put it on the right front and put the right front tire on the left front.Sometimes tires get what they call radial pull and that will fix it or make it go the other way if it goes the other way either get new tires or put the back tires on the front of the vehicle and put the front tires on the back.
Feb 22, 2009 | 1992 BMW 7 Series
Poor breaks
When you open the breaking system you allow air to enter the break lines and that will cause squishy or weak breaks. You have too "bleed" the air out of the lines now. The way to do this is to have someone help you with this process. They will need to pump the break pedal until the break pedal is stiff and hold pressure on the pedal while you open the valve on the caliper or wheel cylinder(disc or drum) until you have a steady stream of fluid with no air. To ensure you get all the air out you need to start from the passenger rear tire,then driver rear, pass. front, driver front. Make sure you slip one end of a hose over the bleeder valve and the other end in a container so that you don't allow the break fluid to contaminate the new brakes,
Dec 03, 2008 | 1995 Chrysler New Yorker
Phil & Teds E3 Jogger Logo
240 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
