Question about Toshiba 50H71 50" Rear Projection Television
Toshiba 50h71 red flashing light.. no pic / sound
Doa
You need to get a new tv lamp BULB.to cheak there is on the side a cover with one srew on do pull out the square box it has your bulb in it,you will no right away that it is broken.don't order it from repair shop it will cost 600.00 get from ebay it is only 225. with shipping.
Posted on Jun 27, 2009
I had the same problem, had the tv out and apart and was about to buy the new bulb when somebody suggested a "hard reset"...unplug the tv from the outlet for about a minute or two, then plug it back in and try it. It worked for me...hundreds of dollars saved by unplugging and plugging back in!!!
Posted on Aug 31, 2009
I have a toshiba - 50h71 - i get a clicking noise from the back of the tv, and the red light on the front flashes, no picture what can cause this
Toshiba Lamp 75008204 Y67
lamps-dlp.com$169.95 Toshiba Warranty 180 Days In a Toshiba Box!
You need a new lamp. simple easy fix. just cost's a bit. Thats the part number for your exact tv. You can probley find it cheaper on E BAY
Mar 11, 2010 | Televison & Video
Toshiba 50H71 Won't Come On
This could be caused by several different things.. your convergence amplifier ICs could be bad, causing 1 of the 2 pico fuses to open up.. another possibility could be bad solder or defective hybrid voltage regulator to be bad (its usually a light brown color).. worse case could be a cracked picture tube hidden by the deflection coil on 1 of the 3 tubes.. might also wanr to check if the horizontal output transistor is shorted..there is also a 1A pico fuse that could be open..
Dec 22, 2008 | Toshiba 50H71 50" Rear Projection...
No pic...humming noice on 62'' toshiba dlp
was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
Nov 19, 2008 | Toshiba 62HM95 62" HDTV
Toshiba 50H71
you need to replace both the convergence ICs they are STK392-110 you can get new replacement ICs at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
May 29, 2008 | Toshiba 50H71 50" Rear Projection...
Fix 50H71 Rear Projection TV
Go to this site and leave an email indicating your model number and what the problem is, they should be able to help you with the problem.
May 24, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 projection tv
You need to replace both of the convergence ICs they are number STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions so you can do the repair yourself which tkes about 30 minutes to do and saves you about 400 dollars. heres the link.
May 18, 2008 | Toshiba 50H71 50" Rear Projection...
Red picture toshiba model 50h71
try to turn down the screen control and see how the tv reacts.
Apr 10, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 50 in. Rear... Problem
set most likely has bad convergence ics J.D.W.
Mar 26, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 50" Rear Projection Television Logo
612 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
