Question about Kicker Car Audio & Video
Amp needs lot of power to work dont kno if i have enough or amp is blown its a kicker zx 2500.1 an older one it powers on with my 8 guage but it bounces back and forth to protect same with and 4 but with a 4 the fan comes on i have no extra batteries dont know what kind of alt. i need to kno if it does that when it doesnt have enough power
  • pimpnigga74 Jun 27, 2009
    are u sure
    even without any thing pluged up it should still power on
3 Suggested Answers
  • 182 Answers
SOURCE: any one kno anything about these kicker zx 2500.1
yea u should as long everything is hooked up correctly ur sound will be great u dont need all that. all of those is because his pushing alot of power and a giant amp its most for that big amp.
so yea hook it up and it should sound good
Posted on Jun 29, 2009
  • 689 Answers
SOURCE: ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Posted on Nov 09, 2012
Nov 09, 2012 | Kicker Car Audio & Video
I have an 06 kicker zx 1500 monoblock amplifier. The other day i was bumping it pretty hard and it just stopped playing so i stopped and then i stopped to look at the amp and the light was off but the...
Check the impedance of the speaker to be sure that it matches the output of the amp. Common error on this detail can cause the amp to overheat and shutdown/protect.
Jul 23, 2011 | Kicker ZX1500.1 Car Audio Amplifier
Wont turn on
try the following;
disconnect your remote lead, connect the remote terminal to the positive terminal with a piece of wire. If the amp powers up then the remote output from your headunit is at fault. You can connect the remote lead to a switchable live at the headunit end to work around this problem. The amp will switch off when you switch the ignition off and vice versa.
If that doesn't work then there may be a problem with your positive feed so check your fuse (there should be one near your battery where you see the amp cable connect)
If that doesn't work, check how secure your earth lead is, kicker amps use a lot of power so these connections need to made to a clean metal surface. Scrape the paint away if you need to, make sure you have bare metal to connect to.
Lastly, if you have only just installed the amp, check that you have thick enough power cable. As I said before, the amp will draw a lot of current, if the main power cable is too thin then you may not be getting enough current to power the amp.
Hope this is helpful.
May 07, 2011 | Kicker ZX-350.4 Car Audio Amplifier
How do i reset my amp? its a legacy LA588.
Sorry but amps dont have reset buttons. Check the fuse if its blown.
Apr 08, 2010 | Legacy LA588 Car Amp
Why is my Kicker 08zx650.4 amp turning off in my 98 Deville??
ive been hearing alot of this going on yes you had youre system proffesionaly installed but youre amp is pushing at all its got it must be pushing at 1ohms capacity loud but what you dont realize is that.. do ur home work first some amps say they can handle the power but if you read carefully it would read not stable look up amp on the net before buyin review them first ...but evrything youve got is correct its youre amp it wont burn out but you wont get continous power to ur spkrs ..i recomend installing one amp on each spkr same brand if you prefer in keeping it with a crossover if you dont have one that way they wont over heat and cutt off and you will use less power and get more bass...
Feb 22, 2010 | Kicker ZX650.4 Multi-Channel Amp - 480W ZX...
Hooking up 6x9's to a amp
yes as long as u put in on the high pass filter (HPF)
Dec 07, 2009 | Kicker ZX200.2 2-Channel Amp - 140W ZX...
Any one kno anything about these kicker zx 2500.1
Jun 27, 2009 | Car Audio & Video
Why would i spend a 100 to 120 dollars on a car amp?
any amp will work with any speaker, you just need to make sure it is a mono amp if you are running 1 speaker and a stereo amp wither 2 or 4 channel if you are running 2 or 4 speakers, the ohm rating on the amp should match the speakers also, on the back of the speaker it has the ohm rating, most will be 8 ohm, but you still find some 4 ohm, depending on the speaker if it has a lot of throw (the in and out movement) you may want a higher wattage amp so you get clean sound, it is up to you.... if you are installing lower price amps to you may hear engine wine or noise while car is running so a grounde loop isolator installed on the system will remedy that... also with the amp the directions will tell you the ohm rating of the wire to use, follow that.... and keep the ground short and clean where ever you put it.. try not to go directly off the battery cause you will get a lot of noise... hope this helps..
Jun 23, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Srt 8 factory kicker system
try running the cables trough a crossover & u can run what u want to what speakers u want
Aug 09, 2008 | Kicker 01C8VR4 Car Subwoofer
Wiring
provided that the memphis studio series is still 1 ohm stable you would wire each coil of each speaker like this : posive to positive negative to negetive on the speaker using 2 jumper wires then run 1 coil from each subs positive and negative the input on the amp that amp would see a 1 ohm load from both speakers as each speaker would become a 2 ohm load. from experience, memphis does not make an amplifier that is brutal enough on power for L7 15" solos, i have the st 1600 d amp running only 2 dual 4 ohm 10 L5's and it is barely enough power for them. For less money than your 2 subs cost retail I can get you brand new matching 2000 watt true competition rated and proven 1 ohm power and 2 subs that would physically fit in your current box, i would however recommend a very very large box for 2 15" squares. you can email me at sicaudio@msn.com , my advice and system designs are always free even if you do not buy thru me. I am usually 1/3 to 1/2 what retail is with full warranties and i can drop ship anywhere in the U.S.A.
Jun 25, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
79 people viewed this question
Top Kicker Car Audio & Video Experts
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
