Question about Goldstar DH4010B Dehumidifier
With an external pipe or even the bucket attached it seem to leak onto the floor below, what am i doing wrong
  • 82 Answers
You may have a blockage in the metal or plastic collection pan under the coil that sweats to take water out of the air. Possibly some pet hair, lint etc. Have you cleaned it lately? Could the pan be rusted through somewhere? Is it level? Could you the collection bucket be cracked at or near the hose connection?
Posted on Jun 27, 2009
My Comfort-Aire Dehumidifier has started leaking water. The unit works fine but the water bucket does not retain all the water. As the bucket fills there are slow leaks. Also, sometimes when replacing the...
It can have leaks from the condenser to the bucket. The piping and hoses should be checked all the way. Perhaps even replaced or at least cleaned. I don't think it is wise to do this yourself. Because in the system also can be algae, bacteria and viruses. And you need tools and skills to replace defective tubes, pipes or gaskets.
Oct 10, 2014 | Dehumidifiers
Dehumidifier seems to be running fine, but water leaking on floor even with minimal water accumulated in bucket?
Hey friend, thanks for your post!
It sounds like your dehumidifier needs to be professionally cleaned. What could be causing the problem is a buildup on the inside of your dehumidifier where the water drains out and it is causing the water to not drain properly. Additionally, I would check to verify that the drain hole is tightly secured with the plug. I know you stated that the bucket is not leaking but have you removed it to verify? Please comment back if further assist is needed. -Matt
Sep 13, 2014 | Frigidaire FDF50S Dehumidifier
Why does Frigidaire dehumidifier FAD704DWD send water outside unit?
Good Afternoon Friend,
I understand that your Frigidaire dehumidifier, model# FAD704DWD, is putting the water that it collects out onto the floor as oppose to the bucket. I suggest contacting the manufacturer for more information. They should be able to point you in the right direction for assistance. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire a/c fad704dwd 70 pint...
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
Amana D965e-e dehumidifier leaking
I encountered a similar problem (using the bucket, but still getting water leaking onto the floor) with my 970E-E. The problem is a design flaw. If the bucket is not firmly pressed into the dehumidifier, there is a slight air gap between the bucket and the dehumidifier on the left side. Within the gap, warm moist environmental air cools. Water condenses in the gap and pools up at the bottom of the bucket shelf, eventually spilling over onto the floor. You can check and see if this is your problem by pulling out the bucket and inspecting for droplets along the left side of the bucket shelf. My solution was the bungie the bucket into the shelf firmly so that there is no air gap.
May 29, 2012 | Amana Dehumidifiers
Hi, I have a Haier HD306 Dehumidifier. I'm having an issue of the water dripping onto the floor. There is no crack or leak coming from the bucket itself. The leak seems to be coming from the back...
When my unit did that, I found that it was because the drain tube was plugged with lint and/or dirt...
Run a large tooth pick or wire up inside the drain and see if the water doesn't start running right out of there...
heatman101
Jul 26, 2011 | Haier HD306 Dehumidifier
Dehumidier works fine! However it leaks water even when the bucket is empty and started. Some water collects in bucket but most runs out on the floor. What is wrong?
The drain hole of drain tube, that transports water to the bucket is clogged.
To solve this problem, do the following:
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helps you solve the problem.
Jul 09, 2011 | Haier HD656E Dehumidifier
Water not going into hose or bucket
where are u located and where aqre u using the unit
a dehumid wont work properly below 60 degrees
or 40 percent humidity
Oct 17, 2009 | Goldstar DH304 Dehumidifier
Leaking water onto the floor. bucket is filling, but is not overflowing. i'm stumped
Take the bucket out, fill it with water, and see if it has a hole or crack. Also look above the bucket and see if the drippage is coming straight down or being diverted by an obstruction.
Aug 16, 2009 | Dehumidifiers
Problem with draining water through hose
I bought one of the FDL70S1 Frigidaire dehumidifiers today for my shop, and found that the $5 hose I bought to drain it through the floor wouldn't tighten down completely, allowing the hose to twist and wobble, a sure indication that it was not water tight. Simply adding a second washer, as described in another answer here, allowed me to tighten the hose sufficiently to produce a tight fit with no play between the hose and the dehumidifier. It hasn't leaked. I know it is a threads-per-inch issue, and I am stumped as to why Frigidaire would supply these units with a different thread pitch than the standard GHT (garden hose thread) 3/4" - 11.5 tpi. The threads on the unit appear to be 3/4 NPS - 14 tpi. Go figure!
Jun 03, 2008 | Frigidaire FDL25P1 Dehumidifier
Goldstar DH4010B Dehumidifier Logo
120 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
