Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
Acer aspire ase380 power switch problem
Acer aspire power switch that has 2 blue led lights does not light. Will this cause my system to not function? Upon turning on the power switch on the back of the system, desktop powers up, but my monitor does not get any signal. I checked monitor with my laptop and it works. Does anyone encountered similar issue?
  • ajmole Jun 27, 2009
    Thanks for responding.
    Screen stays black when I power comp on using my power supply switch. I have two video cards in the comp. One integrated and one the I put in about two months ago. Both of them are NVIDIA. I tried to hook the monitor to both (one a the time), with the same result - black screen. Keep in mind that I did not have any video card conflicts. The integrated card was disabled.
    My front panel power switch does not seems to work. Would that cause no signal being sent to monitor?
    Thanks a lot.
  • ajmole Jun 28, 2009
    Yes, I do. It works with my laptop just fine.
    Sergeant:
  • 199 Answers
Do you get the self test screen on the monitor. is so it is not communicating with comp. bad video port most likely
Posted on Jun 27, 2009
  • chrisbock Jun 28, 2009
    some times monitors just go out. if you un plug the monitoe from the comp do you get a self test screen on the monitor
Why do the speakers hooked up to my Acer Aspire E380 ASE380-UD500A Desktop PC all of a sudden start to hum?
Humming is usually caused by a bad capacitor on the power supply board. Look at the caps on the board, any that are puffed up, burned or leaking (brown at the base) need replacing. Make sure you get the EXACT same capacitors and pay attention to the orientation so you get them back in properly, if you don't you will fry them soon as you apply power to the board.
Jul 21, 2014 | Logitech Audio Players & Recorders
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
What could be causing a load whiring sound in Acer Aspire ASE380-UD440A
The CPU fan. This is normal. Use canned air to blow dust out if it has become louder than usual.
Oct 08, 2012 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Need to hook up the power led
power lead will only fit in one hole at the rear.
Mar 10, 2011 | Acer Aspire E380-UD420A (ASE380-UD420A)...
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Aspire ase380-ud421a cd/dvd drive stopped working
Try going to system setup by hitting Delete when you see the acer/aspire logo when you restart, then open your drive there. If it doesn't work, it is likely that your drive needs to be replaced. You could also try reseating (pulling out and putting back in) the cables inside the computer that's connected to your drive. All else fails, replace the drive.
Dec 19, 2009 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Ma acer aspire 5738z does not atart at all. the power on led nd the on/off buton light glows but the scree remains black. when i last left the comp i put it to sleep nd it went 2 sleep after installing new...
sounds like sleep mode created a conflict while downloading updates.and your pc is still in sleep mode..about the only thing you can try,is reinstalling everything..may work may not
Oct 16, 2009 | Acer Aspire 5735 Notebook
2 SET OF SPEAKERS WON'T WORK FOR ACER E380
Do these speakers came with the system? If yes then check your manual from the Acer's website ( www.acer.com)
Also what color ports do you have in the back of the Desktop?
I believe you have a green, a Blue and a pink port, the Green is for outgoing sound, the Blue is for incoming sound, like a tape player recorder or a External CD player to get sound to your PC, and the PIN is the Microphone.
Feb 11, 2009 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
830 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
