Question about Dryers
My dryer comes on but stays on, the timer switch is broken or something?
  • pterrell718 Jun 27, 2009
    thank you i will try that tomorrow
    President:
  • 1,136 Answers
Hi, You can remove the rear panel on the controls and test the timer for voltage. There are two black wires going to the timer motor. Start the dryer and see if there is 120V going to the timer motor. If there is voltage and the timer does not move, replace the timer.
I hoe this gives you some help. Please let me know if I can assist you further.
Vic
Posted on Jun 27, 2009
DRYER WON'T COME ON BUT TIMER RUNS
make this test and fix it. Merry Christmas
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#top#ixzz2nvE9qYF1
Dec 19, 2013 | Kenmore 62602 Electric Dryer
When I tried to start dryer I hear a lite noise in the area of timer but dryer wount start. Could it be timer malfunction or something else?
Very un-likely that you have a timer problem. Check for broken belt (switch on tension assembly cuts power to motor) a door switch, or possibly a non-resettable drum thermostat out, due to a long or restricted vent.
Aug 24, 2010 | Dryers
Dryer won't start, timer makes clicking noise drum sometimes begins to turn but does not come on.
HI, check the following to address this issue.
The dryer will not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
4. Timer or control board
**The most common issue here will be a defective Thermal fuse, but in this case, the door switch may be the culprit. Check all the areas stated above to cover all suspect issues
Sep 30, 2009 | Kenmore 73952 Gas Dryer
I have a RES7745RQ electric dryer. The timer
3. Thermal fuse
4. Timer
**The most common issue here will be a defective Thermal fuse, but if all is ok with the above stated areas, replace the start switch.
Aug 19, 2009 | Dryers
Kitchenaide dryer won't turn on. . .
3. Thermal fuse
4. Timer
Aug 06, 2009 | KitchenAid Dryers
Dryer is getting Power but not coming on.
Check the following---
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
Jun 01, 2009 | Roper RES7646KQ Electric Dryer
Dryer element stays warm
If it heats w/ the timer in off position whenever plugged in the the element is shorting to ground, its most likely due to either a broken coil or a cracked insulator. If heating w/ timer set for drying but motor is not running, the heat circuit thru the centrifugal/start switch on the motor is stuck closed.
May 16, 2009 | Maytag MDE2600 Electric Dryer
Dryer doesn't turn on
1. No power to the dryerMake sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
3. Thermal fuse
4. Timer
Nov 13, 2008 | Kenmore 659 Electric Dryer
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
Heating element stays on after door is opened
possibly something grounding the element to the housing. what brand of dryer do you have? GE/Hotpoint dryers are good at allowing things like underwires from a bra to get into the element area and ground out the element. or possibly the element has broken and the broken end has fallen against the housing. hope this helps
Oct 29, 2007 | Dryers
Dryers Logo
65 people viewed this question
Top Dryers Experts
Marvin
Marvin
