I have a Kenmore Front loader Model c45192. when not in use it smells very wet and unpleasant
  • 97 Answers
Hello Friend, Your problem is simple to resolve. This is a common issue. It is possible that the water quality being delivered to the washer could contain higher than normal amounts of micro-organisms causing the growth of mold and mildew. Basically what is happening with your washer, when not in use the washer door remains closed trapping in moisture which is the perfect invironment for mold and mildew to grow. You should run a large empty load with bleach and from now on just leave the washer door partially open when not in use. This should resolve your problem. Happy to help, Tim.
Posted on Jun 27, 2009
Kenmore washer mold smell issue
front loader of top loader? For front loaders you need to dry around the front gasket and leave the door open 24 hours after each wash.
Put a couple of towels in the machine and add a full box of Arm and Hammer Baking Soda and do a 90' boil wash. Clean towels and the smell gone.
Jul 17, 2016 | Kenmore Washing Machines
Clothes smell bad when they are dried
Sorry but having no idea what make ,model equipment you use we can not suggest a fix .
Mar 16, 2016 | Washing Machines
Wet clothes after spin cycle and bad mildew smell. I have seen many complaints about mildew smell with He3 & He4 well really frnt loaders in general. The bad mold is so gross and the smell is horrible.
Clean tub boot the best you can with bleach. Then run an empty load with sunlight automatic dish soap (verry little). Then this should clean and freshin the washer up. The best thing to do is not to shut the door on washer when not in use.
Oct 27, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Clothes smell from Kenmore Front Loader
run 3 cups of bleach on high water setting with hot selected as water temp, repeat as ness to eleminate odor
Sep 11, 2009 | Washing Machines
Kenmore fridge started having sparks and has an unpleasant smell
the compressor is asealed unit and wont cause any smell but it does have a push on starter on the compressor pins under the cover (most likely cause)
Possible other faults are defrost element or defrost timer
Jul 27, 2009 | Refrigerators
Sour smell coming from washer even when door is
If you have a front loader it will hold water around the seal of the door and after time it will mold and start to smell.
Jun 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Brown dirt-like looking "gunk" coming out of the washer
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jan 10, 2009 | Kenmore 44832 Front Load Washer
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Jun 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore he2 front loader
We have not heard back on this in about a week. I'm presuimng It's been repaired?
Jun 09, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
