Question about KDS Radius RAD-7 17" Flat Panel LCD Monitor
KDS K717 only displays white screen
I have a KDS K717 model 700p and it will only display a white screen no matter what.
Already changed the control board and problem persists
LadyTech99
  • 141 Answers
SOURCE: monitor stays black
First make sure you have the monitor cables correct. Try another monitor hopefully works so you can go into your device manager and make sure the right drivers are loaded and that your monitor is listed. You may do some research because I'm not sure but I think your monitor uses a back light & an inverter which is replaceable and not usually a difficult job or to expensive. Labor of coarse cost more than the parts. Monitors use a video card or on board video so make sure these are not the problem.
Are you sure its not in wake mode in the bios?
If you shine a light on the monitor when the comp. is on and the monitor light is on you may be able to see your screen. That would be the back light.
When if all and what was going on when it stopped working?
Posted on Jul 07, 2008
SOURCE: kds just two seconds
I have the sameproblem soI plugged in a HP 1702 after 2 days it started doing the same thing. I am using an old school kds with no problems.
Could it be a bug in the system with flat screens.
Posted on Oct 08, 2008
  • 4 Answers
SOURCE: after 15min the monitor cuts off.
power converter/supply bad defect contact manufactuer and ask for warrenty replacement
Posted on Mar 18, 2009
  • 85 Answers
SOURCE: kds k717 screen is black what is wrong with it
Hi
Either the backlight or the invertor have gone.....
IF you still have it under warranty i would suggest contacting them first, or buy a new monitor as if it is the backlight its not worth repairing as you can buy new for not much more.
Also check the cables havent come undone on the unit.
Taz
Posted on Nov 10, 2009
skotkolr
  • 558 Answers
SOURCE: Kds 700p monitor
The most common problem with LCD monitors is the capacitors that are on the power pack. the pack usually looses or pops as we say 2-6 of them after 3-5 years. its almost a certainty after 5 years. a component repair tech can replace these but unless you can find some one like me who will do it for cheap to save the landfill you most likely will buy a new one.
Posted on Apr 29, 2010
KDS K717 MODEL 700P MONITOR works dimly for a second or two and then goes blank.
Your monitor has faulty light bulb(s). Replacement is hard.
Apr 07, 2012 | Computers & Internet
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
Necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
Dec 12, 2010 | KDS K717s 17" LCD Monitor
How do I return my KDS USA monitor back to factory settings for color?
The KDS has an 'OSD' ("on screen display").
Press one button on the front of the KDS to activate the OSD, and navigate through its various menu-items, to find the "reset" control.
Apr 16, 2010 | KDS K22mdwb LCD Monitor
My monitor is fine, I cannot find the power jack. Do you know where I can find one?
Hi
Please see the following link
many available for fairly cheap prices
http://shop.ebay.com/sis.html?_kw=KDS+LCD+Monitor+17inch+17%22+k717+k+/+717+700p+/+700+p&_nkw=KDS+LCD+Monitor+17inch+17+k717+k+717+700p+700+p
I hope this has been useful
Mar 09, 2010 | KDS K717s 17" LCD Monitor
After 15min the monitor cuts off. KDS k717. Iturn it off for a few min and turn it back on and it does it again
Mar 13, 2009 | KDS K717s 17" LCD Monitor
Monitor does not want to come on
Twelve years is a lifetime for a monitor.
May 15, 2017 | KDS 17S 17" Monitor
Monitor stays black
Jul 07, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
The white screen tells me that the display cable (inside your monitor) may be unattached or broken.
The color bands if they are vertical or horizontal lines tell me that your display cable needs to be replaced.
So overall replace your display cable. If this doesn't entirely fix the problem your logic board (inside the monitor) needs to be replaced.
Feb 21, 2008 | KDS K717s 17" LCD Monitor
KDS Radius RAD-7 17" Flat Panel LCD Monitor Logo
207 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
