Question about Briggs & Stratton Garden
Motor died. Can not get it restarted. Checked the plugs, they seem to work fine. Thought it might be the shear pin ,it is fine. Plugs were dry,no fuel on them, kind of expected tthem to have fuel on them.Would like to know what kind of compression pressure should be on the cylinders.Any suggestions greatly appreciated.
  • 422 Answers
SOURCE: 95 4runner
check your asd relay or fuel pump relay
Posted on Aug 24, 2008
  • 111 Answers
SOURCE: Cold Start Idle Issue
Problem might be the air control valve, it's located at the right side rear of intake manifold and has a hose going to the air intake duct from the air cleaner, as a test you might try pinching off that hose when the idle is a problem.
Posted on Sep 30, 2008
redbeard00
  • 957 Answers
SOURCE: Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Posted on Apr 24, 2009
  • 335 Answers
SOURCE: I Have a 2002 blazer that starts but motor dies, surges when accelerating
If this engine is a VORTEC then you may have a problem with the internal fuel system. Under the top plenum there is a fuel reg and poppet valves that inject fuel into the cylinders. Sometimes the tubes that run fuel from the reg to the valves can leak and cause your problem. This cannot be found with pressure check because this occurrs after the reg. PS fuel mileage will go down. Let me know if this helps.Moe
Posted on May 26, 2009
  • 109 Answers
SOURCE: have a 20 HP twin cylinder KOHLER engine on CRAFTSMAN mower.
If you are able...have someone do a compression check on the engine. Usually if a mower is loosing power and it is a twin cylinder engine, one of the headgaskets may be blown.
Posted on May 28, 2009
What is wrong when you push reverse button and the engine dies ?
we had a sled that used to do that all the time. ended up doing a tune up on it and it stopped dying. try changing the spark plugs and double check there are not vacuum leaks into the motor or intake manifolds.
also if the carbs are dirty then they may not be idling high enough to restart when it cuts out for a second to go into reverse....
May 19, 2014 | Winter Sports
Why does my 2000 kx250 flood the cylinder with gas,it will start but only run a few seconds then dies,i pull the plug its wet w/gas,i dry it let the cylinder dry out put the plug back in starts then...
clean the jets replace the float and the pin its less than 100 dollar fix if it dont work order a new carb off amazon it will probly be cheaper to just buy the whole carb
Nov 01, 2013 | kawasaki Motorcycles
Keeps fouling plugs
3 things are the main causes of black soot. 1 not enough air, check air filter. 2 running too rich, lean out the carb. there will be 2 screws on the carb 1 to increase idle speed and 1 for air mixture. While running turn the mixture screw in until it sputters then back it out 1 turn. 3 bad timing. If the mower hits a rock or branch the shear pin can get creased and change the timing(it is to protect the crankshaft from breaking) Here is a link to a youtube video showing how to change the shear pin.
Aug 09, 2013 | Briggs & Stratton Garden
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 | Garden
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have 15 hp mercury hasnt been ran in two year tryin t sell when i first tryed to start it the motor would start run 1 to 2 seconds and die out thought primer bulb was bad went and bought new one then it...
my uncle told me to take the spark plugs out to check if they were dry and if they were to take a spray bottle and put gas in it and spray inside the pluggs and give it full throttle. The motor started on the seconed try.
Jan 15, 2010 | Light Outboard Motor Boat Bass Fishing...
Distributor camshaft gear keeps shearing
Replace the distributor.The weights have collapsed causing this to seize.Thats why now its shattered
Jul 19, 2009 | 1987 Ford F 150
1994 Toyota Camry Won't start.
you should check 3 things. AIr, Fuel, and "spark"
your cars could have many problems. Ignition module, fuel injectors, Mass Airflow Sensor.
You should check into all of these 3 things.
a crank-no start could be many things.
it could even be a cam positions sensors resistance going up when the engine heats up. Cracnk- no start means testing. n like i said
The motor is getting Air, There is Fuel being put into the cylinders, and the Spark plugs are firing.
Mar 17, 2009 | 1994 Toyota Camry
Garden Logo
65 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
